Originally Posted by keakar
I don't understand how this helps without a side by side result from brand new unused oil as baseline comparison?
or is that easy to find online somewhere, and if it is then why doesn't the report show these baseline new foil vs what was found?
I mean, when I look at a report like this it tells me nothing because I have no idea what the "healthy" numbers should be vs "bad" numbers
Good question Keakar, I will try to answer it.
New fluid should not have any of the metals or contaminants listed with values in the lab results. So baseline would be 0.
For fluid properties, the baseline for new fluid or acceptable ranges are detailed in the left column (viscocity, flashpoint, etc).
One factor, the total acid number (TAN), would be the only one that I am not positive what new WS fluid would have.
2008 T4R - SR5 - V6 - Bilstien 5100 3rd clip - Toytech #620 front springs - Total Chaos UCA's - Toytech Superflex rear springs - 275/70/17 (32") BFG KO2 on stock 17" rims - Pioneer deck w/ bluetooth - All synthetic fluid
