Originally Posted by AuSeeker
First and foremost you need to find out why you're getting air in the system and correct it, that shouldn' be happening for that to be happening the system has a break or other leak, etc. that's causing the system to suck air.
I think brakes pads and or calipers and or rotors should be replaced in pairs, i.e. both fronts together, etc. but it can be done singularly, I just wouldn't recommend it.
The air in the system is from when I did it wrong earlier this year. I have not checked to see if there is more air. The brake fluid level is not changing though. Ok sounds good, do you know if the rear caliper guide pin is supposed to have flat spots on it?
Thank you
