09-15-2017, 12:19 PM
Real Name: Anh
Real Name: Anh
Lower ball joints
does anyone know the oem part numbers for front lower ball joints? i think its time to replace mine since i have 243k miles and been hearing not so good reviews on moogs that i bought
09-15-2017, 01:51 PM
You cannot buy toyota balljoints separately for the LCA's. You need to buy the entire LCA. and honestly your better off.
09-15-2017, 02:01 PM
You'd have to buy complete arms. They are absolutely expensive from Toyota though. I got some cheap eBay shit and they seem to do the job
2003 Sport Edition 4x4 V8 with 170k+. 3" spacer lift on Billsteins w/stock coils, SPC UCA's, rear Airlift bags, Flowmaster, 285/70/17 Falken Wildpeak AT3W on 17x9 Dick Cepek rims, LED Interior swap, grill-mounted light bar, Thule roof bars/bike racks with rear lights, Kenwood stereo with Sony speakers
09-15-2017, 02:08 PM
I bought OEM toyota arms from toyota of dallas.
09-16-2017, 01:55 AM
Real Name: Matt
Real Name: Matt
That's a bummer, I'm going to need new ball joints soon. How much are the complete LCA's?
01-18-2018, 07:27 AM
Real Name: Skip
Real Name: Skip
Originally Posted by bonuscup
That's not a ball joint, it's the bracket that attaches to the steering knuckle and lower ball joint.
2004 Limited V8
01-18-2018, 12:56 PM
Real Name: Danny
Real Name: Danny
I went the eBay route too. Both arms for like 150 bucks or something. They seem to be holding up pretty well to the abuse I put this rig through.
01-18-2018, 01:44 PM
If they are not too rustred you can easily rebuild them with new bushings and ball joints. Save yourself maybe $150 each arm. I got OEM bushings and Moog ball joints.
01-18-2018, 07:42 PM
Seems it CAN be done
I struggled with the same issue a couple of years ago. I searched high and low for a way to rebuild the arms myself. In my research, I found some DIYers out here and on Toyota120 who successfully removed and replaced with some MOOG joints. I bought the ball joints and the bushings to do a rebuild and when I went to try and remove the ball joint, found it was WAY too corroded and seized to move. The ball joint kit I got from Autozone began to over stress, despite the amount of Break Free and heat I applied. Ultimately, I said screw it and bought new OEM.
If you want to give it a shot, here's a couple of links I found to help get you started:
lower ball joints
https://www.tacomaworld.com/threads/...tacoma.176251/
And here's the MOOGs:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Good luck!
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
12-08-2020, 02:59 PM
I have an 04 T4R V8 AWD and was looking at replacing the lower ball joints and the dealer is telling me I can’t do the lowers without doing lower control arms....?!! Are they pulling my leg or does the 04 not come serviceable?
2004 SR5 V8 AWD
12-08-2020, 03:07 PM
Toyota does not sell OEM ball joints separately in the states, they were telling the truth. Only way to get oem is pony up for OEM LCA's
Sent from my SM-G986U using Tapatalk
12-08-2020, 03:12 PM
I searched extensively and so did
@ montijo505
when we rebuilt our LCAs. Pretty much have to buy the LCAs as assemblies only, in the US. Theres a loophole someone on TacomaWorld found to get Tacoma ball joints imported to the US, but they have a different taper than 4runner LBJs and aren't compatible. Heres the link to the TacomaWorld post if you'd like to check it out: Aftermarket lower control arms - which one is better? | Page 2 | Tacoma World. Montijo505, a few others, and I went and submitted a request to get the 4runner ball joints on Amayama (the site used to by the tacoma guy to import), but they were unsuccessful at finding anything for us, see his post here: 4th gen LBJ part #.
I've heard good things about Sankei 555 LBJs, I used Import Directs on a recommendation from someone on another forum, and also heard decent things about the Moog greasable LBJs.
edit: Looks like Montijo505 sneaked in here first lol.
12-08-2020, 03:37 PM
Wow I totally thought he was pulling my leg. They looked pressed in to me so I thought it was replaceable. I guess I’ll start doing my research. Thanks for the info guys!!
2004 SR5 V8 AWD
12-08-2020, 03:50 PM
They are pressed in and can be replaced, the Toyota LBJs just aren't available a la carte. I find it odd they sell the LCA bushings a la carte, but not the ball joints, since a consumer or shop would be more likely to replace the LBJs.
I have a thread on LCA rebuild that goes over the LBJ replacement if you want to see some pictures. Whiteline Lower Control Arm Bushing Tutorial (120+ Pictures)
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
