Been a while since I posted anything. First I got some
LFD crossbars for my stock roof rack. These replace the factory crossbars that are attached with plastic hardware, and have a lot of options for mounting a variety of things. The crossbars come with all the hardware needed, but I picked up some security bolts for peace of mind.
I got a Rhino Rack awning, and was able to bolt the brackets to the crossbars (although I did have to drill a hole in the crossbar for one of the bolts).
Besides the awning, I've mounted my hi-lift and also a surfboard to the bars, and they've been great. Highly recommended.
Speaking of the
awning - it's rad. I don't have any pictures, and have only set it up once, but so far so good. Quality is great, and I like that everything is anodized black, even the bolts.
Mounted a fire extinguisher under the driver seat. From what I've read, this is very effective, and I'm a big fan of the size. Let me know what you guys think of this
Element E50 extinguisher.
This weekend I clocked a good amount of time on the front suspension with the help of a buddy. I replaced the LCA's because I was noticing some wear in the bushings, and also the outer tie rod ends on both sides, as one had a lot of play in it. I got Mevotech LCA's, with the intension of rebuilding my OEM arms and putting those back on next time the front end is apart. For the end links, I went with Moog. Besides that, I got some bumpstops from
DuroBumps and they look great. Much bigger than stock, and a progressive rubber. Only a few miles on them, so no feedback yet, but excited to try them out.
Lastly, a shot from the Lost Coast Road. Awesome drive, and pretty easy. I needed 4wd, but not low range.
