Originally Posted by Inv4drZm
I have both. A $60 30" single row light bar and a $18 pair of cubes. A light bar will put out more light but the cubes you can aim towards the ditches to spot deer. My,brother's high end Baja Designs LEDs are nice but I didn't want to spend that much on lighting yet. Considering that my setup is many times cheaper they are a lot better value as long as they don't get moisture inside. I tightened all the allen screws on the covers and you can add more sealant to the inside if you wanted.
He is correct...it all comes down to your budget. If you are willing to pay top dollar - then I would recommend Rigid lights because you get your money's worth. However should you opt for the cheaper route, I would advise you to increase your budget for preventative maintenance like Zm mentioned above to ensure your lights do not go bad quickly.
I have two SR2 10" light bars and a pair of D2 dually flood with one SR2 10" amber on the way. Needless to say I'm satisfied with Rigid lighting - despite the premium price attached to their products. The output is insane and they stand by their products. If you need pictures of the output - let me know.
Currently my setup is as followed: LOWER GRILL DRIVER SIDE: SR2 10" - HOOD SCOOP: SR2 10" LIGHT BAR - REAR BUMPER: DUALLY FLOODS (anti tailgater mod). I plan to replace white with amber for my hood scoop and install the 3rd 10" on passenger side on lower grill to maximize output.
Again it all comes down to whether you're willing to do a one-and-done deal by buying premium lights or opt for cheaper lights + take steps to implement preventative measures to ensure your lights will last long-term
