ok all done and now i got fresh new brakes all around
drivers front had the pins in backwards, the spring was on upside down, and it had a set of two inside pads and no outside pad with the tattle tail squeaker
plus it looked like it was a different type material of pad then what was used on the passenger front.
i think some goober just put in whatever leftover pads he had laying around rather then buy a new set
i cant believe how hard people work at doing things the wrong way sometimes when its easier to just do it the right way the first time
so now after a whole bunch of money spent and eaten alive my mosquitoes, i got all new ceramic brake pads and full set of new rotors at 165k.
i figure i should easily make it to 200k before needing to even check it again, i think the brakes are for sure good for 35k at least but i dont know if i trust the high mileage claims they make about some brake pads but i generally assume 40-50k is the average lifespan you can expect from a set of pads depending how aggressive you drive
