Originally Posted by keakar
ya, but that was the radiator coolant line not the extra cooler in front
come to think of it, i shouldnt be able to blow through the pump side, so if i just blow in each hose, that should tell me which one is just the open return line that dumps back into the pan
I think it was in the same topic as the radiator line topic but towards the end where someone did it via the trans cooler lines and posted his process of doing so, but it is for sure posted on the forum somewhere!!
Edit:
keakar
, As I stated it's in the topic I just mentioned, I went ahead and found it for you even though I really didn't have time to do so just to prove to you that it's on the forum, you need to do a bit of reading and or scanning through topics if you want to find the info you seek sometimes, I know it "much easier" to get others to do the searching for you but it's time you started putting a little more effort in your searches before giving up!!
Look at post #176 posted by jambone and the following post #177 by 4by4runr, (which in this post you even "liked" by the way!)!
ATF Exchange (using the cooling line)
