Old 11-17-2017, 08:38 PM #1
TorqueOfTheDevil's Avatar
TorqueOfTheDevil TorqueOfTheDevil is offline
Real Name: Charlie
TorqueOfTheDevil is on a distinguished road
Real Name: Charlie
4.7 Injector flow rate - and upgrade options
Hi Guys,
Don't hate me, I've strayed over from the 3rd gen side..
I'm really struggling after much googling to find out what the factory flow rate is on the 4.7 2UZ injectors... I'm guessing they are "250ish" (The best I can find so far was a single source on a service manual saying "224-276 cc's")
Initially pre VVTi (Dark blue)... but I'd be interested to know if the later VVTi ones are interchangeable (Brown???), and if so what their flow rate is.
I've just sourced a TRD supercharger, but it looks like my "air assisted" 3UZ (1UZ VVTi/3UZ) injectors wont fit.. so I need a replacement set!
Failing that, do you guys have a go to upgrade path for injectors?
Thanks,
Charlie.
'96 Hilux Surf SSR-X Limited "The HiLex"
--VVTi 1UZ-FE--
-->Build Thread Here<--
TorqueOfTheDevil is offline   Reply With QuoteReply With Quote
Old 11-18-2017, 12:26 PM #2
Real Name: Charlie
Real Name: Charlie
After a little more digging I found an ebay seller stating they are 250CC, which is about where I guessed.
What are you guys doing for upgrades? There seems to be *nothing" when I search!
--VVTi 1UZ-FE--
Old 11-18-2017, 08:01 PM #3
DeathMetalTony's Avatar
DeathMetalTony DeathMetalTony is offline
Real Name: Tony
DeathMetalTony is on a distinguished road
Real Name: Tony
Only information I was able to find on TIS
4.7 Injector flow rate - and upgrade options-2uzfe-png
Instagram @BigHead_805
Toyota Parts @ South Bay Toyota
2007 GX470
DeathMetalTony is offline   Reply With QuoteReply With Quote
Old 11-19-2017, 04:36 AM #4
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
https://www.rceng.com/
These guys made some custome injectors for me for my supercharged 3rd gen. I see no reason why they would not make some for you
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 11-19-2017, 08:30 AM #5
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
I would use these guys before anyone else.
http://www.deatschwerks.com/products/fuel-injectors
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 11-19-2017, 08:41 AM #6
Real Name: Skip
Real Name: Skip
Fuel Injectors | DeatschWerks, LLC
When I visited the Deatschwerks site the only Toyota model they list is a Celica and no Toyotas at all after 2005, nothing else!
2004 Limited V8
Old 11-19-2017, 07:32 PM #7
Real Name: Charlie
Real Name: Charlie
Thanks guys, great information!
I think I may have also found a "cost effective" injector upgrade, - although they are a little larger than planned.
Mazda RX-8 "red" injectors look to be the same shape and size as 2UZ. They are a 12 hole pattern so should give good atomisation, and rated at 350CC, 14.4 ohms.
More Details here - (Looking at that they are also Toyota Tacoma, which might make them easier to obtain for you guys).
I've actually ordered a single used one cheap off Ebay, I'll confirm if it fits!
That DW site is great, the calculators are really handy! - if I go with the RX-8 ones I know I can get my desired power at 72% duty.. so maybe they are not quite as oversized as I thought!
--VVTi 1UZ-FE--
Old 11-21-2017, 06:54 PM #8
Real Name: Charlie
Real Name: Charlie
Hey guys... an update for the sake of the search engine...
RX-8 Injectors FIT!
It's actually a Landcruiser 100 2UZ fuel rail, on an Early TRD supercharger as the "manifold" - but the fitment is the same.
Excuse the state of the manifold.. - the bottom seal is missing but they fit. the impedance looks correct, and the plug pattern matches, - so these should be a straight swap. I've ordered a full set.
As mentioned above, they are rated at 350cc... at 3 bar (43 psi)
Factory RX-8 runs them at 56.5 psi, rating them at 495CC (and very good atomisation).
Denso part number: 195500-4430
13.8 Ohms impedance. (yes the info I've looked up here seems to vary... Must be a Mazda forum thing )
Pretty much the perfect fit. if you need larger, look for the RX8 Yellow injectors.. same fitment but 450cc @ 3 bar.
Hope this helps save someone some time in the future!
--VVTi 1UZ-FE--
Old 10-19-2018, 09:02 PM #9
tv4184 tv4184 is offline
tv4184 will become famous soon enough tv4184 will become famous soon enough
Thanks for the info man. Finding fuel information on my RX7 is pretty easy but hardly anyone does anything on the 4Runner so finding injector / pump / fuel rail info is slightly more difficult. Did you have to get any custom programming to run these properly?
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
tv4184 is offline   Reply With QuoteReply With Quote
Old 10-20-2018, 11:29 AM #10
Real Name: Charlie
Real Name: Charlie
No problem!
In all honesty, I've still not fitted them!
I'm going full standalone as the 1UZ-VVTi that I run is 10.5:1 compression ratio, so I need fine control over what the timing advance is doing for any hope of not grenadeing it.
--VVTi 1UZ-FE--
Old 10-20-2018, 12:08 PM #11
Originally Posted by TorqueOfTheDevil View Post
No problem!
Ah gotcha. Too bad you can't run the UCON EMS from URD. It'll adapt to whatever setup you need on the fly.
Old 10-20-2018, 02:54 PM #12
Morphyne Morphyne is offline
Morphyne will become famous soon enough
How does this compare to the 13 hole injector upgrade?
Morphyne is offline   Reply With QuoteReply With Quote
Old 05-27-2023, 03:43 PM #13
MotorWestPerf's Avatar
MotorWestPerf MotorWestPerf is offline
Real Name: MotorWest Performance, Inc.
MotorWestPerf is on a distinguished road
Post
Here is a list of flow rates and specs for various brands of fuel injectors from Bosch to Weber.
List of Flow Rates and Specs
MotorWestPerf is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 03:24 AM #14
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Call Keith at Dirty Deeds. He's a good guy.
12 Hole Fuel Injectors for Toyota 4.7L V8 Tundra, Sequoia, LandCruiser, 4Runner, Lexus GX470 (Price is for all 8 fuel injectors.)
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 05-28-2023, 04:59 PM #15
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I have the 270cc blue injectors in my 08 4.7. Did not get them from dirty deeds but they are 12 hole ( vs 4 hole OEM ). Got them off ebay. For alot less. Did not notice a huge difference except for a dead smooth idle and the sulfur smell is drastically reduced, almost nonexistent.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Low Loan Rate pag04 Off Topic 18 03-10-2022 02:42 PM
Flowmaster super 40 delta flow or 50 series delta flow? Austin12345 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-23-2015 03:27 PM
Rate this Rust HowardRoark 4th Gen T4Rs 17 09-11-2012 07:06 PM
Flow testing fuel injector? DeTwizzle 3rd gen T4Rs 2 08-20-2012 06:05 PM
k&n intake vs True flow direct flow airintake system statechamp02 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-07-2006 05:43 PM
