Old 11-30-2017, 07:02 PM #1
pudzley pudzley is offline
pudzley is on a distinguished road
Need some help diagnosing battery/charging issue
I got my used 04 SR5 a little over a month ago and noticed an issue the other day. First off, the truck starts perfectly regardless of temperature or other factors... unless there is a load on the battery for literally a minute or two with the truck off.
I noticed this one day after turning the truck off and leaving the doors open for a few minutes (meaning I didn't lock the truck and the headlights were on). This drained the battery enough to the point that the truck wouldn't start. I tested this another day and the same thing happened.
I went to Autozone and according to their battery test, the battery is fine (it's an Interstate battery that looks brand new). They told me the voltage is a bit low with the car running (13.5) and said maybe it's a corroded connection somewhere. They said the battery was only 84% charged after I had been driving the car for a while... but said that it's unlikely to be the alternator. So based on all this, what do y'all think? Thanks!
pudzley is offline   Reply With QuoteReply With Quote
Old 11-30-2017, 07:08 PM #2
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
Did they test the alternator?
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 11-30-2017, 07:48 PM #3
Yes, using the same device as the battery tester... with it hooked up to the battery so I don't know how much I trust it. I've had plenty of people tell me that Autozone tested their battery/alternator, said it was good, and it turned out it wasn't.
Old 11-30-2017, 08:21 PM #4
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
recharge the battery first until its full and test again. the alternator is there to maintain it but when fully discharged, will not work.
Sent from my SM-G930T using Tapatalk
radlynx is offline   Reply With QuoteReply With Quote
Old 11-30-2017, 10:37 PM #5
907YOTA 907YOTA is offline
907YOTA is on a distinguished road
I disagree but like I wife says, I'm always wrong. Say you jump a dead battery and let it run, the alternator should put out about 14.5 volts and charge that battery. So it not really there to just maintain but to also charge.
If you don't have a volt meter buy one, they're cheap and have many uses. I would check the voltage while it's running. Then I would check the voltage when it's off and wait an hour, check it again. It would have to drop off quite a bit for it not to start. My guess is that it's a battery issue or a drain somewhere.
If I'm right let me know so I can tell my wife
907YOTA is offline   Reply With QuoteReply With Quote
Old 11-30-2017, 11:26 PM #6
Registered User
Registered User
you are right, it maintains it and charges it. but if its really very low, you will need to run the car maybe all night. like for example a few days ago, i recharged my battery since i drive it for short distances, around 6 miles to work and 2 mile drives. i pretty much start it 5-6 times a day. it took 6 hours to completely charge it. those short drives are not enough to completely charge it thru the alternator.
to the OP, check how old it is and your driving habits, you might just need to recharge or replace the battery.
Old 12-01-2017, 10:46 AM #7
kingofthehill's Avatar
kingofthehill kingofthehill is offline
Real Name: Who's asking?
kingofthehill will become famous soon enough
Exactly. Very little amperage goes to charging the battery. Most the amperage from the alternator goes to running the electrical system in the vehicle. If you have a low battery it is best to put it on a trickle charger. That will prevent you from overworking the alternator and causing premature failure. Plus car batteries last longer when they are kept fully charged.
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
kingofthehill is offline   Reply With QuoteReply With Quote
Old 12-01-2017, 12:00 PM #8
ZiaMan ZiaMan is offline
ZiaMan is on a distinguished road
Their Alternator tests are crap. I just took my known bad Alternator (battery light on, bearings screaming) to test for fun. It passed. You need to find a place that can do a legit load test. The voltmeter is a down and dirty to see what output really looks like.
Ps - sounds like your battery has some issues if 5min of lights will kill it.
2008 Nautical Blue GX470
Bilstein 6112/5160
ZiaMan is offline   Reply With QuoteReply With Quote
Old 12-01-2017, 01:39 PM #9
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Some other thoughts.
- The advice to buy a multimeter and check your voltages is right on. If you're getting 13.5-14.0 volts or so with the engine running, lights on, etc., the alternator is fine. No need to poke into it further. And don't get fooled by the argument "it can supply voltage, but maybe not current". If the alternator can hold 13.5 volts, it is supplying all the current that the downstream circuits and battery can accept at that voltage. If the alternator was current limited, the voltage would drop. That's just basic Ohms law of electricity.
- A properly working alternator will put out around 13.75 volts. The battery will accept whatever current it can at that voltage. The current will be highest if the battery is somewhat discharged, less if it is deeply discharged or almost fully charged. A dedicated battery charger will typically put out 16 volts or more, which will charge the battery faster, but at the risk of boiling electrolyte if it isn't well controlled. The alternator can certainly fully charge any lead-acid 6 cell (12V) battery, including an AGM.
- Your symptoms point to a bad battery. Easiest thing to do is to replace it, clean the connections squeaky clean (bright metal on bright metal) when you reassemble things, and don't look back. Since your battery is of unknown history, this will also give you confidence for the next 4-5 years.
- 90% of intermittent start problems, in my experience, have been caused by defective batteries. Most of the rest are bad connections. Alternators are way down on the list of things to check unless (a) the charge light is on, or (b) the bearings are making a lot of noise.
Edit: One other thing. When you measure the voltage, measure it directly on the battery terminals, and then on the cable clamps on the battery. If there's more than .1 volt difference, you have a connection problem.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Have you had any problems with your 31M battery on stock charging system? e60ral 5th gen T4Rs 47 04-03-2018 05:59 PM
Battery not charging hondarcb 4th Gen T4Rs 3 03-29-2015 08:41 PM
PLZ HELP! Battery not charging, alternator tests good. swapmeet 4th Gen T4Rs 7 03-15-2015 07:54 PM
Portable battery current draw when charging JB. General Discussions 0 11-10-2011 07:29 PM
Battery/Charging Issue Clemsonfan15 3rd gen T4Rs 8 05-15-2011 03:52 PM
