I believe the system is linked diagonally front to back so only lifting the fronts OR rears will still leave pressure in the lines.
When I did my XREAS delete + lift install, I did the 4 wheel droop procedure. It resulted in a no leaks or spills during disconnect from the check valves as mentioned by
Originally Posted by Bijan
There should be a check valve that a line runs to from each shock. Disconnect from check valve....and remove.
Front XREAS disconnects near the bumpstop
Rear XREAS disconnects near the sway end link
