05-03-2018, 10:49 AM
#16
Real Name: Kyle
Real Name: Kyle
When i installed mine I had to cut apart the fender in order to get the hose to fit. Also it was a pretty tight stretch to get them to attach.
2006 Limited 4WD Metallic Silver
Bilstein 5100s Front and Rear, OME 885 Front and Icon Overland Rear, 1/4" Spacers for driver side, LT295/70R17 Cooper STT Pros, 1" RB Body Lift, 1.25" Wheel Spacers, Stock FJ Rims, Custom Aluminum Roof Rack, Land Cruiser Snorkel, LED interior swap, Cobra 19 Ultra III CB, Vinyl wrapped in Avery Matte Garnet Metallic
05-13-2018, 08:02 PM
#17
I used some 3" PVC pipe. It's a stretch, but works.
What I lack in knowledge & skill,
I make up for with sarcasm & bad jokes.
The Manly Minivan
05-13-2018, 09:44 PM
#18
I ordered a 3in to 4in 45* fitting. Worked out.
Sent from my SM-N950U using Tapatalk
05-13-2018, 10:51 PM
#19
Cool! I'll have to keep an eye out for your 4runner in ABQ! Now that you have a snorkel, I can totally tell it apart from the others. Be ready to get a lot of stares and questions about it.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
07-25-2018, 05:01 PM
#20
4th gen 4Runner snorkel
I used a 2nd gen Tacoma SS171HP and molded it the best I could to the fender and trimmed the flare.
2007 Limited V8 FT-4WD
4x4Labs front and rear bumpers, 4.56 Gears with Harrop E-Locker Front & Rear, Icon CVDC w/ 700lbs spring Ext C/Os & Icon MetalTech Long Travel rear CVDC with HD springs, SCS Ray10s with GY MTRs 305/70R17, Prinsu Rack, Rago MSP and ditch light brackets, Wheeler's Super bumpstops
2007 Toyota 4Runner Limited V8 160,000miles
http://www.toyota-4runner.org/4th-ge...-thread-2.html
08-05-2018, 11:20 PM
#21
Defensor Fortis 02'-12'
" Sammy" 2006 SR5/OME Lift/Wulf UCA/C4 Fab Sliders and Skid/Kenda Klever AT2/BajaRack/Snorkel/Homebrew Drawer/Interior LED swap/TRED Pros
08-06-2018, 12:30 PM
#22
Real Name: Craig
Real Name: Craig
What is the toper you have on your snorkel?
2006 4Runner SR5 4x4 V6
Icon 2.5 ET CO Ft. ICON 2.0 rear with Icon Overland springs. 4.88 Nitro Gears with rear ARB locker, FJ Wheels, 275/75 17 KO2's, Prinsu Rack. RCI Rock Sliders and skids, NWTI Rear bumper with swing out , CBI Ditch Light Brackets LC80 Snorkel. Dual Battery Setup, Busmann fuse block, toggle switches in the overhead.
08-11-2018, 08:03 AM
#23
It’s a self-ejecting precleaner from Donaldson. But there are other companies the make them like Sy-clone, Engineaire, Turbo Precleaner, etc. Precleaners will minimize entry of dust rain water, bugs, snow, etc into the snorkel instead flipping the head. You have to choose the correct prefilter for the engine CFM range. Typically, the gas engines for 4Runners have a max cfm just under 300. So you’ll want something that does 0-300 CFM so that the paddles inside will spin.
https://youtu.be/_6AxqFVipbA
10-18-2018, 03:50 PM
#24
[QUOTE=MightyP;2940641]Rago Fabrication brackets. I had to slide the lights in and it's still close, but they fit.
do you have a close up of the Rago brackets when the hood is closed? wanna see how they look, or maybe a view from driver seat. do you personally feel like they block any of the view? Thank you
10-22-2018, 08:49 PM
#25
[QUOTE=NRAVG;3148743]
They block less than the rearview mirror.
The Manly Minivan
03-12-2019, 07:02 PM
#26
did you remove the stock airbox entirely? Also can you link to the fitting you used to connect the snorkel tube to the car intake
06-17-2019, 08:25 PM
#27
Originally Posted by adkfinn
Using Chrome? Try this: Photobucket Hotlink Fix - Chrome Web Store
Pics work fine for me.
eff pb.
*there are versions for firefox/other browsers out there also.
edit: Glad I could help folks view this content the way it was intended, apologies to
@ afiremensrunner4
for the threadjack. I like your snorkel set up!
It's all good man. This was my first write up so I will try something else next time.
04-04-2020, 08:16 PM
#28
This pre filter....
