Old 12-16-2017, 08:15 AM #1
BOFFROAD's Avatar
BOFFROAD BOFFROAD is offline
Real Name: Brad
BOFFROAD is an unknown quantity at this point
BOFFROAD's Avatar
Real Name: Brad
V8 Cam Seal Leak
After driving with a few other 4runner friends for about 1hr 45min to Hungry Valley for a weekend offroad camp trip I noticed oil all over the lower passenger side of my 4.7 engine. I can't tell where it's coming from. It looks like it is coming from the upper front passenger side of the engine.
2005 Sport V8 4WD Gray
Icon Stage 2 | 285/70/17 BFG KM2 | MB 352 17x9" wheels | 42" led light bar | Side Flood/Camp Lights | Uniball UCA's | K&N CAI | Kicker Sub and Amp | Custom DIY Full Length Roof Rack | Trail Gear 67"
Rock Sliders
Build Thread
BOFFROAD is offline   Reply With QuoteReply With Quote
Old 12-16-2017, 11:32 PM #2
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
It doesn't really look that bad in the picture. Get some brake cleaner and when the engine is cool spray the hell out of it and see if the oil returns.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 12-17-2017, 10:37 AM #3
Slymatic Slymatic is offline
Slymatic is on a distinguished road
Yeah, I've seen a lot worse then whats in the picture. Also, that's a very common area for the oil to start showing if your camshaft seal is leaking. Easy way to tell is to see if there's oil on the lower edge plastic gear cover. If so, try and remove the cover (or at least the top 2 and center bolts) and see if there is oil on the inside of the cover. If there is, your looking at a very large and not so fun job.
Slymatic is offline   Reply With QuoteReply With Quote
Old 12-17-2017, 01:49 PM #4
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
Thanks for the replies. The photo isn't that good but it did lose about half a quart of oil on my 1hr 45min drive. After reading a lot I also think it might be a cam seal. I will try cleaning it off and open the top of the timing belt cover to see if I can locate it better.
Rock Sliders
Build Thread
Old 12-17-2017, 03:47 PM #5
Cruiserfanatic's Avatar
Cruiserfanatic Cruiserfanatic is offline
Real Name: Brandon
Cruiserfanatic is on a distinguished road
Real Name: Brandon
There's no way that small of an oil leak is where you lost a quart and a half. You would have oil all the way down your block and all over the exhaust manifold. Did you legit check the oil level before and after the trip? And if you did, how long was it sitting before you checked it? If it had been sitting say, overnight, before the trip, it's going to be higher than it would be right after shutting it off. It takes awhile for all of that oil to find it's way down, which some of it never does.
2003 4runner Sport V8 - Bone stock
2000 Lesbian Land Cruiser - Again, Bone stock
Cruiserfanatic is offline   Reply With QuoteReply With Quote
Old 12-17-2017, 05:52 PM #6
zerge916 zerge916 is offline
Real Name: serge
zerge916 is on a distinguished road
Real Name: serge
have you figured it out yet?
zerge916 is offline   Reply With QuoteReply With Quote
Old 12-17-2017, 08:30 PM #7
kruton kruton is offline
kruton is an unknown quantity at this point
Camshaft seal
I noticed oil in the same area on my v8 as and pretty sure its the camshaft seal. Not a easy and cheap fix
https://youtu.be/3htWFtHrOPw
06 4Runner SR5 V8 ICON Coil Suspension. RB 1.25 BL.Gibson exhaust from Burtman. Nitto Trail Grapplers MT 295/70/17.ProComp Wheels. Demello Sliders.CBI rear Bumper.
kruton is offline   Reply With QuoteReply With Quote
Old 12-20-2017, 12:08 AM #8
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I believe I have. It think it's the passenger cam seal and so do 2 other Lexus mechanics that looked at it. The thing is, it hasn't leaked since I've been driving it around. I cleaned off as much oil as I could and haven't seen new oil leak. What really sucks is that I did the timing belt myself 10k miles ago. I did not do the cam seals at the time because I read that they were difficult and required a lot more work as the extremely tight cams must be removed. One of the mechanics recommended that I continue to drive with it and watch the leak. He said if it's slow then just try to wait until the next timing belt change so that I don't have to drop $1300 on seals right now.
I am happy that it hasn't leaked anything during short drives around home but I am still worried about the fact that it leaked approximately half a quart during my 1hr 45min drive which did include climbing about 4,000 feet in elevation.
Rock Sliders
Build Thread
Old 12-20-2017, 10:24 PM #9
[QUOTE=BOFFROAD;2868427]I believe I have. It think it's the passenger cam seal and so do 2 other Lexus mechanics that looked at it. The thing is, it hasn't leaked since I've been driving it around. I cleaned off as much oil as I could and haven't seen new oil leak. What really sucks is that I did the timing belt myself 10k miles ago. I did not do the cam seals at the time because I read that they were difficult and required a lot more work as the extremely tight cams must be removed. One of the mechanics recommended that I continue to drive with it and watch the leak. He said if it's slow then just try to wait until the next timing belt change so that I don't have to drop $1300 on seals right now.
I am happy that it hasn't leaked anything during short drives around home but I am still worried about the fact that it leaked approximately half a quart during my 1hr 45min drive which did include climbing about 4,000 feet in elevation.[/QU
Pretty much the same thing I am dealing with. Changed the timing belt out almost 2 years ago and didn't do the cam seals. Just gonna watch mine till the next belt change..might run some high mileage oil with some seal conditioners to see if it helps. Probably wont help but its worth a shot.
Old 12-22-2017, 03:02 AM #10
BOFFROAD's Avatar
Real Name: Brad
BOFFROAD's Avatar
Real Name: Brad
I'll probably do the same next oil change.
Rock Sliders
Build Thread
Unknown leak andrew90lx 4th Gen T4Rs 2 08-23-2015 03:10 PM
Unknown Fluid Leak - Ideas? svana 4th Gen T4Rs 11 01-03-2014 10:17 PM
Unknown fluid leak on '06 4Runner MichaelN 4th Gen T4Rs 13 05-21-2013 12:47 PM
unknown leak 2001 T4R xStePheNyz 3rd gen T4Rs 4 09-12-2010 05:50 PM
Unknown Coolant leak DurtyDogg Classic T4Rs 4 10-07-2008 01:58 AM
