12-19-2017, 04:54 PM
FJ Springs with Billstein 5100s. Data?
Gents,
Looking at putting FJ springs up front and slap some 5100s all around. I’m looking for a 2” lift. not lower than that, or higher than 2.5. I’ve done some searching but surprisingly nothing really of substance came up.
Anybody have any solid numbers of lift achieved with the .85 and 1.75 settings combined with FJ springs?
Thanks
Air 4rceRunner One, 04 Sr5
12-19-2017, 05:58 PM
Originally Posted by simple
Gents,
Thanks
I am in an 06 4WD 4Runner V6 and I upgraded to Bilstein 5100s with front only FJ springs. They are the TRD springs and they had 30k miles on them when I installed. I set them at 1.75 and that got the truck perfectly level (which came out to 2 1/8" of lift in the front). Still riding on stock rear springs till I can find the FJ springs for the rear. I imagine you will yield different results depending on the FJ springs you find and if you are in a 4x4 or V6 or V8.
Also, me and my buddy were able to install by ourselves with no spring compressor so if you need some direction on how to do that feel free to ask!
12-19-2017, 07:38 PM
Real Name: Caleb
Real Name: Caleb
My rig with Moog FJ springs set at 1.75 on 5100's.
2006 T4R Sport 4x4 V8 My Build
1.5 AllPro wheel spacers, Bilstein 5100's with OME 886's with 1/4" Toytec spacers, OME 2896 rear coils, SPC UCA's, LT285/70-17 BFgoodrich KO2's on 2016 wheels, ARB on-board air system, LFD Off Road Skid Plate, DV8 Offroad Tacoma steel bumper with Smittybilt XRC Winch, PIAA 530 Fog Lights, Diff Breather Mod, Limited grille, CBI ditch light brackets and light pods, ARB awning, Wilco Offroad Tiregate,Full size spare tire, RCI Rock Sliders, HCF delete, Smokers kit, Interior LED swap, Map light mod, Pionner AVH-X391BHS HU, Tentbox RTT, Cobra CB, Flowmaster exhaust
12-19-2017, 11:37 PM
That looks great! Moog springs in the rear as well?
12-19-2017, 11:54 PM
This is exactly what I would like to do with my '04 V8. I appreciate you starting this thread and people replying with information and images. I've looked through the lift and tire central posts for 2" lifts but it's hard to find specifics.
Sent from my Pixel 2 using Tapatalk
12-20-2017, 12:28 AM
Here's the GIGANTIC thread on this subject: Compiled: FJ Springs Lift Info for 4th gen
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
12-20-2017, 06:34 PM
Real Name: John
Real Name: John
@ simple
These measurement are to the fender edge when I first lifted mine.
Stock:
RF = 32 ¼” LF = 32 ½ “ RR = 34 ¼” LR = 35”
With FJ set at 2.5 w/ rear 1.5" spacers:
RF 36 ¼” LF 36 ½” RR 36 ¾” LR 37 ½”
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
12-20-2017, 07:08 PM
Real Name: Who's asking?
Sorry to change subject a little. In your signature it states you have 5th gen UCAs. What is the purpose of those? Are they stronger, do they align better with a lift?
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
12-20-2017, 08:46 PM
Real Name: Caleb
Real Name: Caleb
Yep MOOG FJ coils in the back as well.
12-20-2017, 08:48 PM
Real Name: Caleb
Real Name: Caleb
They are essentially the same as 4th gen. I replaced them with 5th gen ones because they had less than 1000 miles on them so the bushings and ball joints were almost new and it was cheaper and less work than replacing the bushings and ball joints on my old arms. I got them from a member on here for like $60.
