Thread Tools Rating: Thread Rating: 3 votes, 3.00 average. Display Modes
Old 03-02-2018, 03:25 AM #31
bagelsjustbagels bagelsjustbagels is offline
bagelsjustbagels will become famous soon enough
Awesome stuff guys!
MY 4RUNNER IS LIVE NOW ON BRING A TRAILER WITH NO RESERVE
2nd Gen (Sold) | T4ROTM Winner
Camping/Overlanding Drawer plans! FREE parts list! -> - TheAdventureIndex.com
bagelsjustbagels is offline   Reply With QuoteReply With Quote
Old 03-02-2018, 10:55 AM #32
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Originally Posted by Joex481 View Post
I believe the missing dado is on the back of the top panel of the casings. I ended up having to do that one while assembling the first casing.
My drawer slide holes didn't line up either. For those still planning I would definitely recommend marking through the slides. Also, don't drill the middle holes until you have the slide mounted in the first two. Made life a lot easier for me.
Yes that's it! I thought it was a bigger piece.
Adam, looking at LH_RH_Carcass.pdf page 2 part 4 (Rear panel) there's no dimension for the height of the panel so it's assumed that it's the same height as the side panels at 10.625" but really since it's not fitting into a dado top or bottom it should be 0.25" shorter than the side panels, dimensioned at 10.375" tall. I ended up taking .125" off of it and dado'ing the back edge of the top panels for a tighter fit.
So it might not be a missing dado but it is a missing dimension for the height of the carcass rear panel that caused the slight confusion.
blackoutt is offline   Reply With QuoteReply With Quote
Old 03-02-2018, 11:45 AM #33
LTDSC's Avatar
LTDSC LTDSC is offline
Real Name: Sam
LTDSC will become famous soon enough LTDSC will become famous soon enough
LTDSC's Avatar
Real Name: Sam
i had the same issue for the tops as well.
LTDSC is offline   Reply With QuoteReply With Quote
Old 03-03-2018, 11:57 AM #34
Ah! Good to know it's at least extra wood and not too little which would result in needing to cut a new piece. I'll try to update the plans asap.
Thanks!
Old 03-12-2018, 10:45 AM #35
blackoutt's Avatar
blackoutt's Avatar
Finished up the finish work on my drawers and sleeping platform this weekend. I choose "special walnut" stain on the outside and left the insides raw red oak then polyurethane coated the whole thing. I added some extra squares to create a ledge for the sleeping platform to sit on the drawers, built a front support for the platform, added some turnbuckles to hold the back end of the drawers down tight since I opted to not build the side wheel well covers, added speaker cabinet handles, added bottle opener that's been floating around on various projects of mine for years. The only downside I've found is that my coleman stove is too tall to fit in the grill spot 3.75" max height and it's like 4". Also the 4runner floor doesn't appear flat even when shimming various places/my wood working skills are mediocre so the beauty panels on the drawer faces don't sit 100% flush level and square on the drawer fronts. Aside from those nitpicks it should be VERY nice functionality wise. Next up is wiring up the dual battery setup to power the fridge and accessories.
Old 03-12-2018, 06:52 PM #36
4Runner010's Avatar
4Runner010 4Runner010 is offline
Real Name: Summit
4Runner010 is on a distinguished road
4Runner010's Avatar
Real Name: Summit
May be a dumb question but is everyone just using CDX plywood thats 1/2 inch or something other.
2003 Build thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
4Runner010 is offline   Reply With QuoteReply With Quote
Old 03-12-2018, 08:58 PM #37
blackoutt's Avatar
blackoutt's Avatar
Most people use birch plywood, I chose red oak because my local menards didn't have enough sheets of birch and Lowe's selection was worse. You could really use anything cheaper that's 1/2" but the hardwood stuff is better to work with for a finished look. Supposed to be better for dados and edge nailing. I think I could have made cdx look almost as good in the end but for all the hours in I'm happy with spending a little more for a solid drawer setup.
Old 03-19-2018, 03:35 AM #38
4Runner010's Avatar
Real Name: Summit
4Runner010's Avatar
Real Name: Summit
Also another dumb question but what screws are you guys using to hold it together? The 3/4 inch screws that bagels has https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
posted they seem really small to be honest.
Old 03-19-2018, 08:23 AM #39
blackoutt's Avatar
blackoutt's Avatar
Wood glue and 18ga brad nails shot through an air nailer. Luckily I have a buddy that had the gun, router, and table saw so I cut and assembled at his house. He seemed to think the glue was the strength and the brads just held it clamped til the glue dried. Based on how flimsy the brads were I'd agree. The dado'ed and glued boxes are pretty strong when assembled!
Old 03-19-2018, 11:04 AM #40
LTDSC's Avatar
Real Name: Sam
LTDSC's Avatar
Real Name: Sam
with being routed and using glue i also used a flooring clean nail. Just for more added grip. They're impressively strong when put together and dried.
I just loaded all my camping gear in my drawers and have some room to spare. Im headed to Pismo this weekend and will take pics while in use.
Old 03-21-2018, 06:51 PM #41
4Runner010's Avatar
Real Name: Summit
4Runner010's Avatar
Real Name: Summit
I’m almost done but thank both of you for replying to my questions but now I have one last one, the right small drawer is there a missing dado or does the sides and the front and back sit on top of the” 2(bottom panel)” or should the front and back panel have a dado on the bottom?
Old 03-22-2018, 10:57 AM #42
blackoutt's Avatar
blackoutt's Avatar
For the small drawer the only dados are the ends of the "side panels" this creates a rectangle that borders around the outside of the "bottom panel". The front/back and sides do not sit on top of the bottom panel. Cut it as shown and dry fit, you'll see what I mean. It would be stronger with slightly different dimensions and some dado's added but I just followed it as is since it's the small drawer.
Old 03-22-2018, 11:30 AM #43
ZOMBRNR's Avatar
ZOMBRNR ZOMBRNR is offline
Real Name: Brandon
ZOMBRNR is on a distinguished road
ZOMBRNR's Avatar
Real Name: Brandon
I got my sidewings done yesterday, minus the tops lol, will do those this weekend.
How are you guys mounting the drawer "faces" without any screws up front?
Build Thread | Enter The Adventure | YouTube | Instagram
2006 V8 4x4 Limited JBL | ZOMB RNR
ZOMBRNR is offline   Reply With QuoteReply With Quote
Old 03-22-2018, 01:23 PM #44
4Runner010's Avatar
Real Name: Summit
4Runner010's Avatar
Real Name: Summit
Thank you I’ve dry fitted it multiple times but the measurements just seem off to me, I’ve probably messed up somewhere and am over looking it haha thanks for the reply. When I’m done I’ll post pics it’s not perfect but it should do nothing some wood puddy can’t fix haha
Also you can screw from the back to the front for the faces or nail it on the sides on the front . That’s what I did
Old 03-22-2018, 01:47 PM #45
blackoutt's Avatar
blackoutt's Avatar
^^^^ yep 1" wood screws with washers from the drawer side pulled the face on nice and tight, then the screws for the handles I put on mine were longer than 1/2" so it added a bunch of extra grab between the beauty panel and drawer fronts.
Looking for plans..Rear Storage to fold out Sleeping Platform? 7B Snow 3rd gen T4Rs 16 01-18-2022 01:00 AM
Custom Storage Drawer FREE (Alexandria, VA) VCU4Runner Free 6 01-08-2015 07:32 PM
FREE Custom Storage Drawer (Alexandria, VA) VCU4Runner For Sale: T4R Items 5 12-23-2014 10:00 PM
Rear Storage Plans + Build thread bryancostanich 3rd gen T4Rs 5 06-06-2011 10:44 PM
