Originally Posted by mttroutchick
Do you know what the weight of this is?
Not to sure to be honest, but it is definately not light. Maybe at least 180lbs on the low end, 300lbs at the high end.
Originally Posted by vonguido
By chance could you go into a little more detail on the electrical setup? The intended purposes, etc.
Great stuff
Sure! The electrical system is a dual battery system with a Blue Sea ML-ACR battery isolator.
the second battery is a costco deep cycle battery that was only $80 and gets the job done.
The Isolator manages the power between the two batteries, and will allow me to jump myself if need be. it also allows me to drain my deep cycle battery without risking my starter battery.
The deep cycle is connected to a Fuse panel, where i plug in my fridge, radios, usb and car charger panel, power inverter, and in the future- lights.
Right now i can go about 2-3 days of fridge and led camp lights before i run out of power, eventually I'll add some solar power but I'm in no real rush.
Hope that helps!
