Coolant Leak
So back in June, I replaced my water pump as well as the thermostat, and the gaskets and o-rings for everything. Over the summer, I drove from North Jersey to North Carolina twice as well as countless trips to the shore and some towing. Never Lost a drop of coolant. Now that it is below freeing, I am loosing coolant from the pipe that sticks out of the block and goes into the outlet housing. It is only leaking when it is cold. I'm using the Toyota coolant and have no other leaks. Im wondering if I should replace all the O-rings and the outlet housing, or just do the o-rings. Anyone have this problem? It is an 09 with the 1GR-FE.
