hi, with respect to people's concern about interior cab heat (blowing warm on one side cool on the other) I too need help with this too
T4R not getting same temp from passenger side and driver side on "heat" settings. A/C settings seem to be equal.
(my T4R is a 04 V-8 limited with auto-temp control) I am in Canada, it gets cold here so the heat needs to work.
-If I select "hi" temp (max hot setting on both drive and passenger side) and use the climate control manually, I select heat location and the fan speed, then I get good solid warm air everywhere.
-If I select select "hi" temp (max hot setting) and then select the "auto" setting, then I get good solid warm air everywhere.
-* If I select select a value such as "26" temp and then select the "auto" setting, this is where the problem happens. example the driver side will blow at 26 deg C (79F), but the passenger side only blows at 19 deg C (66F) or cooler.
-at this point if I adjust the passenger side tempt to about 31, then both sides will be similar
-in the summer I do hear some random "gurgling" noise (or it maybe like a stripped plastic gear noise) that seems to come from behind the radio or behind the glove box
I feel like this should be more of a blend door or temp sync/calibration issue?
has anyone actually fixed this issue?
(my coolant is relatively new, it is full, it has been "burped", a/c works fine)
Originally Posted by Powder_Hound
I’m working out this exact issue now and completely baffled.
Confirmed Thermostat is good
Coolent level is good
Flushed Heater Core
Hot drivers left face and cooler moving to passenger
Cool air to rear vents
Cool air to passenger lower
Dealership is quoting $1650 to replace heater core due to being “clogged”. But, why would there be some “heat” if heater core is clogged?
I did add a new radio last summer, but I haven’t dug into it to check on alignment of vents. Has anyone ever figured out if it’s a blend door actuator or a savor or WTF else could it be?
