Old 01-09-2018, 12:24 AM #1
TT4RLtdV8's Avatar
TT4RLtdV8 TT4RLtdV8 is offline
TT4RLtdV8 is on a distinguished road
TT4RLtdV8's Avatar
Battery Light + Whine + Low Idle + New Battery
Evening Gents.
After searching and reading a few threads on a battery light issue, I'm looking for a little clarification/direction.
2006 V8 AWD. 217k. Timing belt and water pump done at 215k, serpentine done at 208k. I have NOT done the secondary air bypass, but I do have the kit in my garage ready to go.
After having my Toyota dealer install the timing belt and water pump, I noticed in the mornings the truck would make a whirring sound with what I thought was a fan clutch engaging and disengaging. It would not do this when the truck was at temp.
I got a battery light a few nights ago. Took it to Autozone and had them test it and the alternator. The battery wasn't doing so hot, and the alternator came back fine. Slapped a new battery in with 750 cold crank.
After putting the new battery in, the battery light did not go away. The whirring has gotten more noticeable. Video here.
Gut says alternator. But I've also seen posts regarding ground issues at the fender, alternator, or ECM.
Electrical testing shows the battery at a 12+ V reading, and when running and with throttle it jumps to 13-14, so that says the alternator is functioning, but the whirring tells me it is on its way out? Or is it something completely different like a dying powersteering pump or... something else?
Thanks for your time and opinions.
2006 V8 4WD Limited - DT Long Tubes, Y Pipe, Gibson, TitaniumWorks, Bilstein, RESZ Links, ARB, orangeBoxx MOLLE and dead pedal, Pedal Commander.
TT4RLtdV8 is offline   Reply With QuoteReply With Quote
Old 01-09-2018, 04:59 AM #2
D. Le D. Le is offline
Real Name: Derrick Le
D. Le is on a distinguished road
Unplug the alternator and see if noises change. If yes, then bad alternator. I'm pretty sure it's bad alternator. Also check to see if that power steering pump isn't leaking down onto that alternator.
D. Le is offline   Reply With QuoteReply With Quote
Old 01-09-2018, 08:28 AM #3
djkurious djkurious is offline
djkurious is on a distinguished road
I would suspect a bad alternator being the battery light is on.
Does the voltage drop once the whine starts?
2003 4Runner SR5 V8
319k and counting...
djkurious is offline   Reply With QuoteReply With Quote
Old 01-09-2018, 08:30 AM #4
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Nope. I almost wish it would have, would have saved a post and I’d have a new alternator on the way by now!
Sent from my iPhone using Tapatalk Pro
Old 01-09-2018, 08:42 AM #5
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Never thought about it leaking. These noises / issues started after Toyota put the timing belt on. Do you think something could have happened on the reinstall that caused the leak -> subsequent alternator failure?
Old 01-09-2018, 10:09 AM #6
ZiaMan ZiaMan is offline
ZiaMan is on a distinguished road
Went through something similar for about 9months. Had a really weird whine/groan that thought was the power steering pump. Would come and go and usually only happen during the first start of the day. Fast forward and I'm about 2 days away from buying a new PS pump and the battery light comes on. Alternator the whole time.
Just for funsies, I took the bad Alt to Autozone to have it tested and it PASSED. So take that for what it's worth.
I also replaced my acc belt with the alternator and made things a lot more quiet. Guessing the old one was stretched. Maybe the new one put enough more tension on the alt to kill off marginal bearings?
Went with a Rebuild from Partznet and am happy.
2008 Nautical Blue GX470
Bilstein 6112/5160
ZiaMan is offline   Reply With QuoteReply With Quote
Old 01-09-2018, 10:53 AM #7
kingofthehill's Avatar
kingofthehill kingofthehill is offline
Real Name: Who's asking?
kingofthehill will become famous soon enough
I used to work at AutoZone, while in college. The alternator test is not full proof. There has been several occasions in which I tested a bad alternator that tested good. In many cases a bad alternator works better when cold (on the bench test) and when the engine first starts (higher rpm for minute or two). In this case it would typically be a bad voltage regulator. On the other hand if the diodes in an alternator fail then it will always test bad.
2005 4RUNNER V8 4WD -- Sony XAV-AX100 -- Bilstein 5100 shocks -- Wheelers T1/T12 Springs -- 5th Gen Wheels -- 2006-09 Tail Light Conversion -- AFE Pro Dry S -- X2Power 24f -- ScanGauge II...
kingofthehill is offline   Reply With QuoteReply With Quote
Old 01-10-2018, 01:03 AM #8
Were you able to unplug it? Might have access through the passenger side apron.
Old 01-10-2018, 01:34 PM #9
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Not yet. My work week has been keeping my in front of a computer all waking hours instead of my toolbox. Friday I’ll tear into her. Have a new alternator just in case, and it’s time for plugs, oil change, and secondary air bypass.
Old 01-10-2018, 03:00 PM #10
alextmullis's Avatar
alextmullis alextmullis is offline
alextmullis will become famous soon enough
Sounds like mine when the alternator went
alextmullis is offline   Reply With QuoteReply With Quote
Old 01-10-2018, 07:08 PM #11
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
My truck did the same thing when I used a winch for too long. It just smoked the alternator and the light came on. Once I slapped in a new alt, everything was good.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 11:17 AM #12
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Well. My alternator arrives today. Which is good because my truck died on me last night driving home. Luckily it died in my neighborhood walking distance from my house. Got it to start with a quick battery charge and got it back to my garage.
Thanks for your input all. Turns out the best way to confirm a troubleshooting exercise is to experience a failure.
Old 01-11-2018, 04:51 PM #13
Keep us updated!
2003 4Runner SR5 V8
Old 01-11-2018, 07:02 PM #14
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Keep us updated!
I’ll be tearing into it in a few hours. Wish me luck haha
Old 01-11-2018, 10:51 PM #15
TT4RLtdV8's Avatar
TT4RLtdV8's Avatar
Alternator swapped. Started at 7:30 pm ended at 9:22 - had a buddy and a half help (the half showed up to tighten nuts on the new alternator, steal a beer and leave).
Full write up when I’m not on my phone.
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
RPM at idle lower than usual after battery disconnect insaniak 4th Gen T4Rs 5 05-17-2016 10:21 AM
Trouble starting, Low idle, Battery Won't charge BrandonF 3rd gen T4Rs 2 12-28-2014 08:05 PM
new battery, rough idle murderface 3rd gen T4Rs 4 07-19-2013 02:42 PM
Low Idle / Bad Battery / Bad Alternator ??? Boomboombd 3rd gen T4Rs 4 12-05-2012 09:53 PM
