01-10-2018, 12:41 AM
Real Name: Stephen
Real Name: Stephen
ICON UCA (Delta Joint) Dust Covers
Hey All,
I just got myself some Icon UCA's along with the rest of my lift, and want to get some of the dust covers that Icon sells. The issue is that they are $45 bucks! I don't want to pay that much for two small aluminum pieces. Does anybody have some, and if so could you get me some dimensions? I am thinking I might try to 3d model them and then do some 3d printing to make them. If you have any alternative suggestions as well, that would be great!
Thanks!
01-10-2018, 01:07 AM
Real Name: Stephen
Real Name: Stephen
Pre-Concept Section View
01-10-2018, 07:02 PM
Real Name: Adrian
Real Name: Adrian
Looks good man. Having a 3D Printer would be amazing for this very thing.
01-10-2018, 10:38 PM
Real Name: Sean
Real Name: Sean
Originally Posted by Stephen5217
Hey All,
Thanks!
I don't have the delta joints, but I do have the regular tubular control arms and the dust covers. The diameter on mine is: 2.463"
If I remember correctly, mine did not have any part that stuck straight down under the dome (Like you have in your CAD). It was just a flat cover and two adhesive disks.
Hope this helps. . .
'06 Sport V6 4x4, Icon Stage II, Gobi Stealth Rack, Shrockworks Sliders, Shrockworks Front Bumper, Comeup 9.5rs, RCI Aluminum Skids, 285/70/17, ARB CKMA12, Icom 2730A
01-11-2018, 12:08 AM
Real Name: Stephen
Real Name: Stephen
The covers for the tubuluar w/uniball and the delta joint are the same. I'd like to design them so that they are press fit, and don't need the adhesive... it just seems like too much a paint to clean/grease them.
So the outside diameter is 2.463? I found this picture on a tacoma forum, and I assume that theirs are the same pretty much. Do you have the dimension of that inner ring part? I guess I could just measure off of my control arm
Who would want to buy some if I could print them for a reasonable price?
01-11-2018, 01:07 PM
I like the idea of a press fit cap, but I also don't mind dealing with the adhesive rings. My only complaint is the $11 + shipping and tax ICON wants for replacements. My head started to hurt trying to sort through the 3M website for which neoprene adhesive ICON includes in the kit. I need to make another attempt to find an alternative.
01-11-2018, 03:07 PM
Real Name: Sean
Real Name: Sean
When I bought mine Icon sent one set of installation adhesive rings and one set of replacement adhesive rings along with the caps.
01-11-2018, 03:13 PM
Real Name: Sean
Real Name: Sean
Sorry, I don't have the inner dimension.
I couldn't get my calipers in the with the dust caps and the joint installed. Hope somebody else can chime in for you.
01-11-2018, 08:37 PM
Real Name: Stephen
Real Name: Stephen
No worries, I'll pull some measurements off of mine in the next couple of days. The battery in my calipers died
02-03-2018, 09:50 PM
Any update on the 3D printed press fit dust caps?
06-05-2018, 04:39 PM
Real Name: Adrian
Real Name: Adrian
The Delta Joint UCA's how no moving parts underneath the cap. I imagine a 3D printed cap for a Delta Joint arm would be much easier then the uniball version.
12-02-2018, 11:25 AM
Any update on this?
Sent from my Pixel 3 using Tapatalk
02-05-2019, 11:21 AM
Originally Posted by BendRunner
Any update on this?
Interested in an update as well. Just put on delta joints!
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
