Old 01-11-2018, 09:32 AM #1
EnduringGuerila's Avatar
EnduringGuerila EnduringGuerila is offline
Real Name: Tim
EnduringGuerila is on a distinguished road
Real Name: Tim
Post 5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)
I have looked across the internet and found a lot of information spread throughout but nothing that was easy to follow.
THIS THREAD was the most helpful. (51 pages of information)
I am only trying to compile all necessary information to make the upgrade easier for everyone.
UPDATE:
Some people are still having issues with the calipers still seizing. This seems highly situational and I haven't taken the time to look for a pattern of causation.
I personally have had 0 issues and absolutely love the added stopping power. (Installed everything in March 2018 and it's currently Jan 2023)
This is a very easy upgrade caliper swap.
The mounts are identical and line up perfectly.
4th Gen Sport models (Sport Brakes Package optional on the Limited) have larger front calipers (13WH) and rotors than the SR5 models (13WG) so no modifications are necessary. The rear calipers/rotors are the same for all 4th Gens.
Yes, this upgrade DOES work on SR5 but the dust shield/covers need to be modified/cut or upgraded. (Just like the 3rd gen 4Runner -> Tundra caliper upgrade)
SR5 owners have the option of "upgrading" their brakes to the Sport brakes but these still have the seizing issues.
The 5th Gen calipers have shown less issues with seizing than the 4th gen calipers have. (my front left caliper seized which prompted this thread)
The 5th Gen front and rear caliper pistons are (2.5mm-3mm) larger than the 4th gens (not sure if this is compared to 13WH, 13WG or both)
The 5th Gen front rotors are 4mm thicker than the 4th Gen rotors. (this extra thickness helps with heat dissipation and warping)
The 5th Gen front rotors are the same diameter as the 4th Gen Sport (338mm or 13.307") (SR5 has 319.024mm or 12.56")
5th Gen Front Rotors:
Nominal Thickness: 31.8mm (1.25")
Minimum Thickness: 29mm (1.14")
4th Gen Front Rotors:
Nominal Rotor Thickness: 27.94mm (1.1")
Minimum Rotor Thickness: 25.908mm (1.02")
It is possible to use the larger (Sport) 4th Gen rotors with 5th Gen calipers...
The pistons in the calipers will over extend when the pads get warn down if you use the 4th Gen front rotors with the 5th Gen calipers. It is highly recommended to upgrade the rotors too
It is even less recommended to use the SR5 rotors with the 5th Gen calipers because of the smaller rotor diameter in addition to them being thinner.
5th Gen Rear Rotors:
Nominal Thickness: 18.034mm (0.71")
Minimum Thickness: 16.002mm (0.63")
Outside Diameter: 312.166mm (12.29")
4th Gen Rear Rotors:
Nominal Rotor Thickness: 18.034mm (0.71")
Minimum Rotor Thickness: 16.002mm (0.63")
Outside Diameter: 311.912mm (12.28")
Both 4th and 5th Gen rear rotors seem to work. Proofs:
5th: BlackWorksInc and measurements, Runn4est, JeffMerr, verman84
4th: 084RUNNAH,
The argument of why it might better to use 4th gen rotors: pjbrownva
ACDELCO 18A2735 (5th Gens) Center Hole Diameter 107.95 MM
ACDELCO 18A1227 (4th Gens) Center Hole Diameter 106.17 MM
That is the section of the rotor the emergency/parking brake uses like a drum brake (brake shoes press against the inside of the rotor)
Here are the other vehicles with the calipers we're after.
Front Calipers: 14WA
  • LEXUS GX460 2010-2015
  • TOYOTA 4RUNNER 2010-2015 (THEY CHANGED THE FRONT CALIPERS OF THE 5TH GENS STARTING IN 2016 which will not work)
Rear Calipers: F14 and braket 14B?
  • LEXUS GX460 2010-2017
  • LEXUS GX470 2003-2009
  • TOYOTA 4RUNNER 2010-2017
  • TOYOTA SEQUOIA 2001-2007
If you are debating whether or not to change the rears in addition to the fronts: Slowgoat here verman84 here M1911 here
When buying calipers, you'll usually have these options (source):
  • Unloaded - Caliper
  • Semi-Loaded - Caliper, caliper mounting bracket, hardware, no pads. (<-- Recommended)
  • Loaded - Caliper, caliper mounting bracket, hardware (shims, sometimes bolts, rubber thingies, metal retainer thing), pads
Most calipers do not come 'finished' and will rust quickly. I highly recommend painting them, properly, if you do not buy them already painted.
JeffMerr and pjbrownva (with pictures)
Brake Pads:
4th Gen (Sport and Limited models) Have the same pads as the 5th Gen 4Runners (source1)(source2)
Wheels:
17" wheel recommended. Some aftermarket 16" work (like the FJ Cruiser TRD Pro 16s) but stock 4Runner 16" wheels will not. (source)
Brake Bleeding: (See Post #2 in this thread)
Brake Bleeding section of 4Runner repair manual. Link to PDF
I can't find any Speed Bleeders that claim to work on the 5th gen calipers. They may be different based on the (re)manufacturer.
Centric Front (141.44287 and 141.44288) Bleeder is 7mm x 1mm
Centric Rear (141.44587 and 141.44588) Bleeder is 10mm x 1mm
Duralast Front D6278 and Rear 19-B2737 calipers: 10mm x 1mm
Cardone(Wearever) Rear caliper Bleeder is 10mm x 1mm
Speed Bleeder(brand) (their website):
pjbrownva here ordered Front: SB7100-SS Rear: SB1010-SS Order Total: $70.00
DoctorMegaly uploaded a video on YouTube. He also used SB7100-SS for his front calipers (7mm x 1mm)
3/16" hose recommended for most nipples
My personal installation guide... (didn't have time to document, bought PWR-KC138-36 and stainless braided Front and Rear lines)
Let me know if I left out any helpful information and I'll add it to the original post.
USEFUL LINKS/THREADS
5th Gen Calipers by 084RUNNAH
Rockauto is a good place to order parts
(everyone has been able to get a refund for their core charge even though they returned a different model caliper) proof1 proof2 proof3 $15 return shipping?
Centric Calipers: (Cart Pic) Total [Before Core Fees: $188] [With Core Fees: $467.16]
Centric Rotors: (All Prices Pic) [Daily Driver Total: $186] [Heavy Duty Total: $298]
Eye candy (pictures) and part numbers from GLW68
5th Gen Caliper Install Gone Wrong? by fdbyrne
4th Gen Brake Upgrade Glock_19 by Ducmonsta
Rotors and brake pads recommendations? by Keyen702
Brakes need pumped twice to work correctly by buck_sez
Long but extremely educational video: Brake Replacement - A Focus on Brake Hardware
2003 Limited 4WD V8 4Runner (Build Thread)
2008 CBR600RR (picture)
EnduringGuerila is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 09:41 AM #2
Real Name: Tim
Real Name: Tim
How to fix spongy brakes:
Originally Posted by Kmvreter View Post
See the attached pages from the FSM.
I've been through this (with multiple caliper changes) and here is what I found works for me to eliminate the spongy pedal.
Ignore the content in the document about the tester.
It's an electric MC pump so start by bleeding with the ignition ON, engine off. The order is somewhere in the document.
Even with a good bleeding you need to finish with step 2a & b (or 5a). If you have previously done a good bleed then skip right to this step. Do the following with the ignition OFF. They say depress the pedal 40 times but here is where they are short on detail. Forty quick on/off cycles is a waste of time. Do 15 or 20 second cycles. Think of how slow air bubbles travel in brake fluid. Depress and hold the brake for 20 seconds, then let go and wait 20 seconds. Imitate the normal braking stroke as if driving. Repeat 40 times. The pedal may bottom out but hold it there. You will feel the pedal go solid at around 20 cycles but don't stop the cycles there. Do 40 cycles. Give yourself 30 minutes to do this.
Repeat as needed over several days and your brake feel will return.
Hope this helps.
Link to PDF he attached
Parts 084RUNNAH Ordered:
Originally Posted by 084RUNNAH View Post
From Rockauto
Calipers:
Centric 141.44587
Centric 141.44588
Centric 141.44287
Centric 141.44288
The two sets of rear brake lines are:
1 set at the calipers
The other set is at the rear axle allowing it to flex with the axle.
Rear Caliper Brake Flex Hose Stainless Steel Numbers:
950.44507
From All-Pro
Front Caliper Brake Flex Hose Stainless Steel Numbers:
5500FJT-AP-F x 2
Rear Axle Brake Flex Hose Stainless Steel Numbers:
5500FJ-AP x 2
Brake flex hoses are optional
lunchindabox said here "I ordered the front brake lines a couple bucks cheaper at PureFJCruiser.com
Image of part #s on the boxes
Rotors:
Centric 120.44174
Pads:
Akebono Performance ASP976
Originally Posted by ZiaMan View Post
Here are the Centric 5th Gen Caliper vs. 4th Gen Caliper via Rockauto. Looks like the 5th are indeed 3mm larger in piston size.
5th Gen: CENTRIC 14144288
4th Gen: CENTRIC 14244228
Originally Posted by GLW68 View Post
Parts list:
Front Brake Caliper Upgrade Left CENTRIC 14144288
Front Brake Caliper Upgrade Right CENTRIC 14144287
Front Brake Dust Guard Upgrade Left 47782-60120
Front Brake Dust Guard Upgrade Right 47781-60120
Front Brake Rotors Upgrade Left CENTRIC 12644174SL
Front Brake Rotors Upgrade Right CENTRIC 12644174SR
Rear Brake Calipers Upgrade Left CENTRIC 14144588
Rear Brake Calipers Upgrade Right CENTRIC 14144587
Rear Brake Rotors Upgrade Left CENTRIC 12644175SL
Rear Brake Rotors Upgrade Right CENTRIC 12644175SR
Front Brake Hose Left CENTRIC 95044007 StopTech Stainless Steel
Front Brake Hose Right CENTRIC 95044007 StopTech Stainless Steel
Rear Brake Hoses to calipers Left ACDelco 18J4472 (Centrics kept shipping without the copper washers 3x)
Rear Brake Hoses to calipers Right ACDelco 18J4473
Rear Brake Hoses to frame Left CENTRIC 15044397
Rear Brake Hoses to frame Right CENTRIC 15044397
Front Brake Pads Upgrade AKEBONO ACT976
Rear Brake Pads Upgrade AKEBONO ASP606
http://i34.photobucket.com/albums/d1...ork/Brake1.jpg
http://i34.photobucket.com/albums/d1...rk/Brake3c.jpg
http://i34.photobucket.com/albums/d1...ork/Brake2.jpg
Old 01-11-2018, 10:58 AM #3
aquilon aquilon is offline
aquilon is on a distinguished road
great documentation. This should be a sticky!
aquilon is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 02:40 PM #4
Runn4est Runn4est is offline
Real Name: Steve
Runn4est is on a distinguished road
Real Name: Steve
This is a great consolidation!
I'm glad you made mention of Blackworks post on the rotor bore size. I've seen a lot of skepticism lately on the rear 5th gen rotors being used. People have claimed to me (even after I successfully installed the brakes) the e-brake wont work properly...I can confirm that I am successfully using 5th gen rears with no issue and the e-brake works as intended.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
Runn4est is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 02:45 PM #5
ndjose ndjose is offline
ndjose is on a distinguished road
One correction though. The larger brakes on the Limited were an option. I had to bend back the dust shield on mine (03 V8 Limited)
ndjose is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 02:49 PM #6
Also, i believe you need 17" rims to clear the caliper, so with the SR5 it can be an issue.
Old 01-11-2018, 03:14 PM #7
verman84's Avatar
verman84 verman84 is offline
verman84 is on a distinguished road
verman84's Avatar
Awesome job.
Everything you wrote is a great summary of the process. My suggestion is to go with the 4th gen rear rotors. I went with the 5th gen and the access holes to the parking brake tensioner star nut don't line up entirely correctly. Go with 4th gen rear rotors.
Also, I would make this super bold and large. Paint your calipers or buy them already painted. These things rust ridiculously fast. Mine turned orange in a few months tops and I don't even live in the rust belt. Really wish I had painted them.
2008 SR5 v6 4x4 - Galactic Gray, Bilstein 5100, Nitto Terra Grappler G2 265/70/17
verman84 is offline   Reply With QuoteReply With Quote
Old 01-11-2018, 03:57 PM #8
Real Name: Tim
Real Name: Tim
I'll rephrase it then. Everyone that has a Limited seemed to have the 13WH so I assumed it was standard.
I already mentioned this in the "Wheels" section. It isn't very large so it's probably easy to overlook.
Originally Posted by verman84 View Post
Awesome job.
I'll try to word the recommendation so it sounds more motivating haha
Old 01-11-2018, 04:26 PM #9
Cory619's Avatar
Cory619 Cory619 is offline
Cory619 is on a distinguished road
Cory619's Avatar
I just did this upgrade. What a difference in braking. The installation is straight forward. The Gen 5 rotors and calipers go right on.
I have the parts lists in another thread. I purchased everything from Rock Auto.
BPOWER STOP S2736 Performance Red Powder Coated; Includes: Caliper, Hardware, and Bracket; Includes: Caliper, Hardware, and Bracket Info
Rear x2
$155.58
Remove
BPOWER STOP S6278 Performance Red Powder Coated; Includes: Caliper, Hardware, and Bracket; Includes: Caliper, Hardware, and Bracket (where applicable) Info
Front (Only 2 Remaining)
x2
$233.58
Remove
Brake & Wheel Hub : Rotor
Related Parts
CCENTRIC 12644175SL StopTech Sport Slotted Info
Rear Left
$67.89 $0.00
1
$67.89
Remove
CCENTRIC 12644175SR StopTech Sport Slotted Info
Rear Right
$67.89 $0.00
1
$67.89
Remove
CCENTRIC 12644174SL StopTech Sport Slotted Info
Front Left
Previous Image
Next Image
$82.79 $0.00
1
$82.79
Remove
CCENTRIC 12644174SR StopTech Sport Slotted Info
Front Right
Previous Image
Next Image
$87.79 $0.00
1
$87.79
Remove
Brake & Wheel Hub : Brake Pad
Related Parts
AAKEBONO ACT606 {Click Info Button for Alternate/OEM Part Numbers} ProACT Ultra Premium Ceramic Pad Info
Rear; OE Pad Material Is Ceramic
$39.79 $0.00
1
$39.79
Remove
AAKEBONO ACT976 {Click Info Button for Alternate/OEM Part Numbers} ProACT Ultra Premium Ceramic Pad; Includes Shims Info
Front; OE Pad Material Is Ceramic
$44.79 $0.00
1
$44.79
Remove
Subtotal $780.10
2004 Limited 4Runner, OME 885 5100, BFG 185/75/17
Cory619 is offline   Reply With QuoteReply With Quote
Old 01-12-2018, 08:04 AM #10
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
Great summary! Should be a sticky!!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 01-27-2018, 01:55 AM #11
tv4184 tv4184 is offline
tv4184 will become famous soon enough tv4184 will become famous soon enough
Nice the video by DoctorMegaly is actually my former roomate. I was up there visiting when I picked up my 4th gen and drove it back here. Small world! I saw there was another video of someone else doing the 5th gen swap that was a bit longer too.
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
tv4184 is offline   Reply With QuoteReply With Quote
Old 01-27-2018, 06:20 AM #12
N4RNR N4RNR is offline
N4RNR is on a distinguished road
If I want to change out my SR5 dust shields to accomodate the 5th gen brake mod, should I get the 4th gen Sport dust shields or can I just get the 5th gen dust shields. I'm assuming 5th gen dust shields will fit, is it identical to the 4th gen Sport dust shields?
I know most with SR5s just bend them, but I don't mind doing a little extra work to put the bigger shields on.
2007 4Runner V6 4WD
N4RNR is offline   Reply With QuoteReply With Quote
Old 01-27-2018, 10:03 PM #13
DMV4runner DMV4runner is offline
Real Name: William
DMV4runner is on a distinguished road
Real Name: William
5th gen to 4th gen brakes
I swapped my 2008 SR5 over to 5th gen brakes (rotors and calibers) almost 1.5 years ago without any issues. It bolted right up without any adjustments. I just bent my dust shield out of the way and haven't had any issues with it since.
I used Speed bleeders SB 7100-SS M7x1.0 and SB 1010-SS M10x1.0 to bleed the system afterwards.
I didn't have any problems using the 5th gen rears and aligning up the hole to adjust the e brake.
It really significantly improved the braking on my 4th gen. It was well worth it.
W
Failure is written in pencil. "This sucks" builds character.
Embrace the suck
DMV4runner is offline   Reply With QuoteReply With Quote
Old 01-29-2018, 07:17 PM #14
Real Name: Tim
Real Name: Tim
The 5th shields aren't really an upgrade. I personally recommend just bending or cutting them and spend the extra money on something else.
I used a Dremel when I upgraded my 3rd gen 4R to Tundra calipers.
Old 01-29-2018, 07:35 PM #15
Slowgoat's Avatar
Slowgoat's Avatar
Don’t breathe the brake dust in from dremmeling the shield. There is asbestos in brake pads and the brake dust. Wear a mask please. Spray it down well with brake cleaner.
A good friend is in the final stages of dying from asbestos dust. It freaking sucks bad. I want you to be healthy man.
brake , calipers , upgrade
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
How much better do the brakes get with the Tundra upgrade? mirraman 3rd gen T4Rs 41 04-22-2015 02:26 PM
Brakes Upgrade <<<< 4th Gen T4Rs 4 07-25-2010 01:39 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
