Old 09-24-2018, 10:42 AM #31
Scotte30m3 Scotte30m3 is offline
Scotte30m3 is on a distinguished road
I'm looking at doing this swap... does any one know if I can use the 16" OEM wheels with spacers for the OEM 16 wheels to clear?
Scotte30m3 is offline   Reply With QuoteReply With Quote
Old 10-05-2018, 08:27 PM #32
neurotictim neurotictim is offline
neurotictim is on a distinguished road
I've got 5th gen calipers and front rotors on the way from R1 Concepts, along with 4th gen rear rotors. Gonna do them when I do the lift, hopefully before Thanksgiving. Pretty sure I got the right stuff due to this thread, so thanks!
neurotictim is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 12:48 PM #33
bgebhard bgebhard is offline
bgebhard is on a distinguished road
So my 4th gen truck had the conversion done but the PO used budget calipers and of cousre they where sticking. I bought fronts that went on No problem, but the rears i got from Napa the brake line hose fitting was to big for the slot on the new calipers (2010 4runner caliper). Anyone run into this?
bgebhard is offline   Reply With QuoteReply With Quote
Old 01-08-2019, 12:53 PM #34
I had read just about every post about doing the conversion. I did read in one of the post that someone with spacers and 16" wheels made it work.
Old 03-29-2019, 12:55 PM #35
MikeinNH67's Avatar
MikeinNH67's Avatar
So people have had 5th gen calipers on their 4th gen trucks for a bit now. Is it worth the hassle/cost or do they stick just as much? My fronts need some work.
thanks,
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 03-29-2019, 01:08 PM #36
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
thanks,
They aren't really a "hassle". As far as I know the price difference is negligible as well. If your old stuff is failing and you have to get new stuff anyways, you may as well get "better" new stuff. I just installed my stuff last weekend so I can't speak to the longevity, but the braking performance increase is definitely noticeable. If you decide to do this swap, make sure to sure 4th gen rear rotors. 5th gen rear rotors caused a slew of issues during my install.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-29-2019, 09:35 PM #37
MikeinNH67's Avatar
MikeinNH67's Avatar
Thanks, this would only be for the fronts as my rear were replaced before I found this. Hassle/cost being core charges for the wrong core being brought back but maybe they wouldn't even notice. I'm thinking it may be best to buy local so I can have lifetime warranty for when they start to seize again. From what I've read it seems the Gen5 do it sometimes too.
Mike
03 4runner Limited
Old 04-02-2019, 09:27 PM #38
overlandout's Avatar
overlandout overlandout is offline
overlandout is on a distinguished road
Would this kit work?
Power Stop High Performance Brake Kit with Calipers | Power Stop
The part numbers don't seem to be the same on the rock auto website. I couldn't find the rotors mentioned earlier in these posts.
overlandout is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 07:02 AM #39
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Yes, but your better off not ordering the complete set of 4 like that because, as mentioned, the rear rotor has a different bore that causes problems for some. When I ordered mine, I went for the z34 towing/heavy duty pads, but everything else is the same. I ordered the pad and rotor kit for the 2010 front, pad and rotor kit for 2004, then ordered the calipers separately for 2010. The pads for the rear are all the same, as is the rotor thickness and diameter, so the 5th gen caliper bolts right up. The 5th gen rear calipers just had a slightly larger piston or something, so I went with those and then 4th gen rotors and pads. Very happy with the performance so far, and they look awesome! Just hope they last...
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 04-03-2019, 10:36 AM #40
Awesome! Thanks for the quick response. I've been needing this for a while. Braking performance has been getting worse and worse.
Unfortunately, I'll need to replace my CV joints soon, and suspension. Its going to be a pricey year.
Old 04-03-2019, 05:43 PM #41
CampingT4R CampingT4R is offline
Real Name: Mark
CampingT4R is on a distinguished road
Real Name: Mark
2010 Front Pads, Rotors, and Calipers (Z36 Extreme) -
RockAuto: https://www.rockauto.com/?tab=search...rtnum=KC587336 $435.79, (refundable core of $96)
Amazon: https://www.amazon.com/dp/B079396VZL/?tag=powsto07-20 $392.99
2004 Rear Pads and Rotors (Z36 Extreme) -
RockAuto: https://www.rockauto.com/en/moreinfo.php?pk=3802839 $150.79
Amazon: https://www.amazon.com/dp/B005UB5O46/?tag=powsto07-20 $164.99
2010 Rear Calipers -
RockAuto: https://www.rockauto.com/en/moreinfo.php?pk=4491219 $157.58, (refundable core of $60)
Amazon: https://www.amazon.com/dp/B00DGRQYMC/?tag=powsto07-20 $156.21
SS Brake Lines -
Goodridge 2-21186 G-Stop Brake Lines | Autoplicity $149.21
Amazon: https://www.amazon.com/Goodridge-2-2...gateway&sr=8-1 $154.75
Parts cost after core refunds: $722.37
If someone can confirm the parts above I’d greatly appreciate it! Also, as I understand it this will work on my 2003 SR5 V8 with 17” wheels as long as I cut/bend the brake shields.
CampingT4R is offline   Reply With QuoteReply With Quote
Old 04-08-2019, 06:28 PM #42
Maz0019082 Maz0019082 is offline
Maz0019082 is on a distinguished road
Rear Disks Caution!
I just did this swap and wanted to throw in a word of caution regarding the rear disks. For the record, my 4Runner is a 2006 Limited that had the upgraded 'Sport Brakes'. I used 5th gen (2010) TRD pads along with Napa remanufactured calipers and ultra premium coated rotors. The fronts had zero problems.
After assembling the rear I had a clicking noise coming from the passenger side of the tire at all times exactly once every rotation. Through troubleshooting, I found that-
-It only happens when the lugs are torqued on.
-Removing the caliper doesn't fix the problem.
-Backing the parking brake all the way off doesn't fix the problem.
After swapping back and forth a number of times I noticed small play around the hub with the new rotors that wasn't there on the old. Looking up the specs the center hole is slightly larger on the newer rotors. I swapped to new 2006 rotors and the problem is resolved.
I believe this extra play around the hub allowed the rotors to get locked down off center. This wobble in the rotation was binding at one point on the brake shoes, but only one and only for about a cm patch. I never use my parking brake and believe if I did and the pads were worn even slightly more the problem would not have surfaced. In that case, the rotors would still be slightly off hub centric though.
Use 4th gen rear rotors
Maz0019082 is offline   Reply With QuoteReply With Quote
Old 04-09-2019, 09:17 AM #43
I ran into similar problems over the weekend with my install. I think you're right. Unfortunately. I rebuilt my parking brake with new hardware/springs. That seemed to fix it for now, but I may swap back in the end.
Old 04-09-2019, 12:30 PM #44
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
thanks,
Don't want to be "that guy", but after doing the "5thgen" upgrade, I have to say, "meh". I haven't noticed any significant increase in brake performance, at least nothing tangible. I got the Centric calipers (at the time they didn't come painted) and painted them with G3 paint. Guess what? In about a years time, they seize up f*&^ing again. Had to rip them out and get "specially coated" ones from Rockauto. So far, so good. I did the 5th upgrade in the hopes that the seizing would stop. It hasn't and it won't.
There is a thread that MIGHT tackle this (Truly Fixing Seized Calipers) problem. Guy is coating his pistons to stave off corrosion. The boot design sucks and is prone to failure. However if the innards of the caliper are specially coated, the seize problem could go away. Very interesting.
My advice to those who are due for new brakes: Just stick with OEM size (unless you have the smaller brakes), get the specially coated calipers (for those in the rust belt).
Ed
CookieRoe is offline   Reply With QuoteReply With Quote
Old 04-11-2019, 06:06 PM #45
MikeinNH67's Avatar
MikeinNH67's Avatar
Ed
I just replaced them with the ones listed for the truck, just no time to play with something that may not be quite right depending on wheel size and such. I did get coated rotors and calipers for the front so we'll see how they hold up. It stops really well now.
Mike
03 4runner Limited
brake , calipers , upgrade
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
How much better do the brakes get with the Tundra upgrade? mirraman 3rd gen T4Rs 41 04-22-2015 02:26 PM
Brakes Upgrade <<<< 4th Gen T4Rs 4 07-25-2010 01:39 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
