Old 04-12-2019, 11:25 AM #46
GLW68 GLW68 is offline
GLW68 is on a distinguished road
Originally Posted by MikeinNH67 View Post
So people have had 5th gen calipers on their 4th gen trucks for a bit now. Is it worth the hassle/cost or do they stick just as much? My fronts need some work.
thanks,
OK, so an update after 2.5 years and ~21,000 miles:
This is still the best upgrade I've done to my 4R. The braking performance is SIGNIFICANTLY better than stock (2003 Limited 2WD). The truck sits outside 24/7 and I live in an area that gets lots of salt in the winter. They still perform perfectly. I usually lock up everyone's seat belts with their nose in the dash LOL, when I drive it after not having been in it a while because they stop so well compared to our other vehicles.
In fact, I noticed that the wife's 2004 GX470 was braking very poorly and I'm in the process of upgrading those to 5th Gen fronts. (Rear on GX470 is already the same as 5th gen 4R rears)
As far as the aforementioned hoses; I chose to use braided stainless on the fronts and just rubber on the rear set. Couldn't get RA to send the right Centric part number (inside the box was missing parts) after multiple tries, so went with the Delco from Amazon to finish the job.
So, yes it is worth it to upgrade.
Also, yes the rear rotor is just slightly too big for the hub, and I get a little click on occasion that doesn't affect performance. Parking brake works just fine. If I ever need to replace it in the future, I'll likely use a Gen4 rotor with the Gen5 caliper.
GLW68 is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 01:43 AM #47
DrRobot DrRobot is offline
DrRobot is on a distinguished road
I have a 07 4runner SR5 2WD, all the pads and rear rotors are still good, can I install 5th gen front and rear calipers with 5th gen front rotors without changing the pads? Thanks!
DrRobot is offline   Reply With QuoteReply With Quote
Old 07-04-2019, 07:46 AM #48
Real Name: Skip
Real Name: Skip
The brake pads are exactly the same part for 4th Gen or 5th Gens T4Rs.
If you ever do change out the rear rotors use 4th Gens rotors and not 5th Gen rotors, the 5th Gen rear rotors have a larger center hole that goes over the axle flange hub and could be off center enough to allow the parking brake shoes to drag.
2004 Limited V8
Old 07-04-2019, 11:38 AM #49
Thanks! exactly what I wanted to know
Old 11-12-2019, 06:17 PM #50
MAZE MAZE is offline
MAZE is on a distinguished road
Originally Posted by EnduringGuerila View Post
Some aftermarket 16" might work but stock Toyota 16" wheels will not.
I think it's safe to say conclusively that 16" wheels will not fit.
I test fit a 14WA caliper with my 16" Level 8 MK6 winter wheels. The inner diameter of the wheels hit on the top center of the caliper and prevented the wheel from fully seating on the hub(+rotor).
Guess I'm buying WG calipers with the extended warranty :/
5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)-img_7525-jpg  5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)-img_7530-jpg
MAZE is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 12:52 PM #51
underscorepatrick underscorepatrick is offline
Real Name: underscore
underscorepatrick is on a distinguished road
hey guys. I just wanted to know. If i purchased calipers without the brackets, are they a direct swap? Also,I called my local autoparts store & he said there were two options. I just ordered some Calipers & rotors online,& they only had one option .
underscorepatrick is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 11:51 AM #52
digitalliquid digitalliquid is offline
digitalliquid is on a distinguished road
I did this swap on my 2004 6 cyl
Just wannted to echo what other said the 5th gen rotors will work but produce a clicking noise which seems to come from play in the rotor because the holes where the lugnuts go are slightly to big. Rode my 4runner with 5th gen rotors for 2 years before noticing super uneven wear on one sides pads and not the other. Also noticed binding when lug nuts were tight, not sure why this wasnt an issue till later. Also we removed the rotors without using the star so had to rebuild the ebrakes for both side. So
TLDR
1. 5TH gen rotors work but are not ideal use 4th gen rotors
2. If you have clicking when in reverse you bent your ebrake hardware. (Specificly the _n_ shaped pin and lower spring behind the star nut adjuster.) Dont do it.
Thanks for the help guys, glad I can put some advice back in.
digitalliquid is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 01:18 PM #53
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Originally Posted by r32 View Post
Thanks for this and everyone who contributed to all the other threads referenced here. So awesome! I'm in process of ordering all the parts now. Over $1000 worth.
I'm a bit slow and I was still a little confused on the hoses from Centric since GLW68 listed both rubber and stainless hoses from Centric, as well as two other hoses from ACDelco. I put together this little chart on Centric hoses to hopefully clarify things for anyone else confused on this.
Note, there are 6 brake line hoses required for the 4th gen 4Runner. However, when using Centric’s parts catalog search feature for StopTech Stainless Steel Lines, the search results reveal two types of hoses (007 and 507) for a total of four hoses. There are no stainless steel hoses available from StopTech (by Centric) for the rear uppers. Therefor, if you want to go with Centric hoses for the rear uppers, you will have to go with 150.44397 rubber hoses.
rubber hoses from Centric
2 Front - Centric 150.44362
1 Rear Left Lower - Centric 150.44408
1 Rear Right Lower - Centric 150.44407
2 Rear Upper - Centric 150.44397
stainless steel from StopTech (by Centric)
2 Front - Centric 950.44007
2 Rear - Centric 950.44507
Alternatively, you could order the G-Stop Brakeline Kit (part #21186) from Goodridge which comes with 6 stainless steel hoses. However, some have reported this kit to be more of a pain the ass to install.
Also note, when searching Amazon for brake lines from Centric, you must use the period [ . ] in the part number. Some people here list the parts without the period, but the search results on Amazon will come up empty.
Anyone do "just" the 4 Centric SS lines (w/o swapping the upper rears)? I'm considering just doing that.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 11:42 PM #54
gn9119 gn9119 is offline
gn9119 is on a distinguished road
The 5th Gen front and rear caliper pistons are (2.5mm-3mm) larger than the 4th gens (not sure if this is compared to 13WH, 13WG or both)
At the risk of being accused (rightly perhaps) of being lazy/cheap, i have a stuck piston on left rear caliper on '06 V8. Could i just put a gen 5 caliper on that side and leave the original on the right rear. Wear on that side is even, but the left side's inner pad is worn down about to the shim while the outside pad is fine.
I'm putting new rotors and pads across both R/L rear and need to address the stuck caliper one way or the other. Was going to just stick a 4th gen on there but read about 5th gen swaps so here we are...
'06 4RV8Lim
FW, TX
gn9119 is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 12:23 AM #55
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
No, you should always do brakes in pairs. So if you replace one with a Gen5 caliper, you should replace both with the same on that axle, be it front or rear.
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-23-2020, 08:53 AM #56
what i figured
'06 4RV8Lim
FW, TX
Old 02-05-2020, 10:33 PM #57
Rhedbeard Rhedbeard is offline
Rhedbeard is on a distinguished road
Is it required to get new brake lines when upgrading the 4th Gen 4Runner to the 5th Gen calipers? Or just an opportunity to install better brake lines?
'07 SR5 V6 4x4 | Dobinsons GS59-220B/C59-302R | Icon Delta Joint UCA | ICON Front Swaybar Bracket/Diff Drop | Dobinsons GS59-701B/C59-327R | SE59-529 | Full RCI Aluminum Skids | SCS RAY10 | 285/70/17 BFG AT KM2 | Prinsu | 5th Gen Brake Upgrade/Powerstop F&R/Extended Rear Brake Lines | Odyssey | More
Rhedbeard is offline   Reply With QuoteReply With Quote
Old 02-06-2020, 11:28 AM #58
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Just an opportunity. Also, to reiterate what I'm sure you already know, DO NOT use 5th gen REAR rotors. Stick with 4th gen rear rotors.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 01:08 AM #59
I appreciate the response. Probably time for extended brake lines anyways. Definitely NOT going to use 5th gen rotors for the rear!
Old 05-27-2020, 01:04 PM #60
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Getting ready to do this myself. Has anyone had any luck getting a core return? I figure were probably SOL since we're returning a 4th Gen caliper when we bought a 5th Gen, but figured I'd ask.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
brake , calipers , upgrade
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
How much better do the brakes get with the Tundra upgrade? mirraman 3rd gen T4Rs 41 04-22-2015 02:26 PM
Brakes Upgrade <<<< 4th Gen T4Rs 4 07-25-2010 01:39 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
