Old 05-27-2020, 08:18 PM #61
laufer's Avatar
laufer laufer is offline
laufer is on a distinguished road
laufer's Avatar
Originally Posted by gimlithepirate View Post
Getting ready to do this myself. Has anyone had any luck getting a core return? I figure were probably SOL since we're returning a 4th Gen caliper when we bought a 5th Gen, but figured I'd ask.
I had no issues with these specific core returns at Advance Auto about two years ago.
Blue Rhino - KD9IOJ - Stratosphere Mica 2004 4Runner Limited 4WD V8 (UZN215)
- front: 5th-gen TE springs w/ Bilstein 5100s set to 1.75", rear: Dobinson C59-599 1" lift springs
- Cooper A/T3 S4 255/75R17 - 5th-gen brake calipers and front rotors
- Kenwood DMX7704S digital media receiver HU
laufer is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 08:11 PM #62
Prudii Prudii is offline
Prudii is on a distinguished road
I'm planning on doing this upgrade soon with my 2007 SR5, it does have the 17" wheels. I was planning on buying the POWER STOP KCOE5874 kit from rock auto.
Has anyone used this kit and know if it would or would not work?
Edit: Apprently they wont work because I need 4th gen rotors.
So as best I can tell all these parts should work:
5th gen front brake kit KCOE5873
4th gen pads and rotors KOE2405
5th gen read calipers L2736, and L2737
All from powerstop.
Prudii is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 12:34 PM #63
Schnurd Schnurd is offline
Schnurd is on a distinguished road
Has anyone purchased the full 5th gen kit from PowerStop and had it work? If you select 2010 or 2011 it should give you everything 5th gen and all bolt right up correct?
Z36 Extreme Performance Truck Brake Kit with Calipers | PowerStop
Schnurd is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 07:55 PM #64
dontek dontek is offline
dontek is on a distinguished road
Front Splash Guards
I realize it's not necessary, but if a person wanted to replace the splash guards instead of bending/shaving them, are these the part numbers that will allow for the Gen 5 rotors?
Front Brake Dust Guard Upgrade Left 47782-60120
Front Brake Dust Guard Upgrade Right 47781-60120
These are listed as 4th Gen parts. I'm guessing these match the Sport brake option?
2006 SR5 4WD V8 4Runner - just starting the build
dontek is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 01:45 PM #65
chompster4runner chompster4runner is offline
chompster4runner will become famous soon enough
I just did the front 5th gen rotors. I only had to push the shield away from the rotor and that’s it. Rear 5th gen rotors won’t fit the 4th gen rear.
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
chompster4runner is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 04:01 PM #66
Ryanmurgs Ryanmurgs is offline
Ryanmurgs is on a distinguished road
I’d like to chime in here on having just attempted this install. I got the 5th gen power stop calipers (#S6278) for my 4th gen sr5 as well as duramax 5th gen rotors.
The calipers bolted on no problem (after modifying the dust sheild). When I went to install the wheels, the drivers side cleared the caliper by about 1mm, but the passenger side hit the caliper. I have the 17” trd Tacoma wheels with 1.25” spacers. I double checked that I had everything mounted flush and correctly and I did, so I’m not sure why I was not clearing on only the passenger side.
I figured a quick solution would be getting 1.5” spacers to add 1/4” of clearance, but after doing that they both still barely cleared by 1-2mm. I drove around on it a bit, and took it all apart to re inspect and my caliper on the passenger side has definitely rubbed a tiny bit on the inside of the wheel. Has anyone else ran into an issue like this?
Ryanmurgs is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 05:55 PM #67
That's really weird. I also just completed this upgrade with Centric parts (stuck with 4th gen rear rotors) and had zero clearance issues. My only real problem was severely rusted flange nuts on the hard lines and ending up spending and extra $80 to replace them all + some new bolts that broke off when removing the hard line mounts from the rear axel. My only bizarre experience was that for some reason the bleeders on the rear calipers were different sizes.?.
Old 09-08-2021, 06:49 PM #68
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
So is this upgrade with it? Are stopping distanced decreased? Anything else you notice that’s an improvement over new 4th Gen brakes?
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 02:15 PM #69
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Been running the 5th gen front caliper rotors and 4th gen rear set up for a few years... I think it's worth it.. there is benefits to stopping performance and longevity of the parts.
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 02:40 PM #70
cnmurray14's Avatar
cnmurray14 cnmurray14 is offline
cnmurray14 is on a distinguished road
cnmurray14's Avatar
Is it rubbing the rim, or do you have weights that it's rubbing? I just did the powerstop calipers on my 4th with trd rims and had the calipers rubbing the weights on the inside of the rim. Had the tire shop rebalance with weights out of the calipers path and all was solved.
Sent from my SM-N981U using Tapatalk
cnmurray14 is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 06:22 PM #71
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I need new calipers and am already boasting the larger rotors since I'm a V8...are the 5th grade calipers better than 4th Gen sports? I just swapped rotors and SS brake lines, those won't need upgraded to other parts, will they?
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 12:47 PM #72
LOSTR4's Avatar
LOSTR4's Avatar
Here's what I purchased:
EBC Brakes USR7237 USR Sport Slotted Coated Brake Rotors, 2 Wheel Set EBC-USR7237
Dynamic Friction 1214-0976-01 Heavy Duty Semi Metallic Towing Brake Pads With Hardware DFC-1214-0976-01
Stoptech 950.44007 Stainless Steel Brake Line Kit, 2 Wheel Set STT-950.44007
Stoptech 501.00001 600F Brake Fluid
If I am to upgrade to the 5th Gen fronts (eventually rear), will I now need to replace the already installed/new rotors and pads to fit the 5th Gen-sized calipers?
**Looks like I'd need rotors/pads/calipers if I went 5th gen...I'm not able to buy new rotors as I've already installed my EBCs...are the Powerstop calipers worth owning for perhaps a little longer life than a potential reman caliper? Arrrrgh! I wish I did a finer degree of research on this!
Old 05-09-2022, 03:20 PM #73
LOSTR4's Avatar
LOSTR4's Avatar
I realized my rotors I bought are too small...so, this new stuff I installed this weekend was merely an expensive practice run...I need new rotors, calipers, and pads...but hey, at least my brake lines & fluids are fresh and ready! :P
Didn't some rotors offered on 4th gen creep up to like 373mm?
Old 05-09-2022, 06:57 PM #74
LOSTR4's Avatar
LOSTR4's Avatar
Anyone?!
Old 05-09-2022, 10:52 PM #75
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Not that I'm aware of?
Standard was 312x28mm and Optional was 338x28mm... I don't recall them ever getting that big. Are you thinking of line that BBK the FJs had for a short while before getting recalled? I don't even remember what size those were...
BlackWorksInc is offline   Reply With QuoteReply With Quote
brake , calipers , upgrade
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
How much better do the brakes get with the Tundra upgrade? mirraman 3rd gen T4Rs 41 04-22-2015 02:26 PM
Brakes Upgrade <<<< 4th Gen T4Rs 4 07-25-2010 01:39 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
