Old 05-10-2022, 10:36 AM #76
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Well, I now have a better understanding of what I bought and what I thought I bought...last year I bought 319mm (12.6") rotors and thought I had purchased the 338mm (13.3")...well, time passed and I installed them last weekend, I bought the wrong size rotors paired up with seizing calipers on one piston of each side...a gong-show if I must say...NOW, I have on order the 5th gen Powerstop calipers & 5th Gen DBA 338mm rotors and pads...I'm hoping this will fix my issue...I apologize for the thinking on the 373mm rotors...this was precedented on what I thought was originally the 338mm rotors and noticing they are WAY too small..
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 10:57 PM #77
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I'll have to replace my brakes this year... not sure if I'll upgrade the fronts to 5th gen stuff or just do new pads and rotors yet.
Something I was wondering, has anyone had a machine shop make you guys a centering ring for the larger rotors?
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 11:07 AM #78
LOSTR4's Avatar
LOSTR4's Avatar
Don't the lug studs do that?
Old 05-11-2022, 12:25 PM #79
Technically yes... but they have a bit of slop, normally not an issue because the hub centers the rotors so the slop is rotational (think advance/retard on a Cam gear vs. Both rotational and up/down).
The lug nuts conical tips should center the rotor when the wheel is installed, but I imagine if you ever tried to use an on car lathe to turn them it'd be inconsistent at getting a good cut.
Old 05-24-2022, 03:21 PM #80
derekdevasia's Avatar
derekdevasia derekdevasia is offline
Real Name: Derek
derekdevasia is on a distinguished road
Real Name: Derek
5th gen parts for sale
I completed this 5th gen brake upgrade on my 4th gen and they preform great. I went to do this to my dad's 2nd gen Tacoma, and being the complete idiot that I am realized he had 16 inch wheels after the fact.
That being said, if anyone is interested in OEM brake rotors, calipers, and pads all bought from McGeorge, they're available for local pickup in the Virginia Beach/Tidewater area.
I'll sell it all for 350. In brand new condition. Receipt will come with. Open box, and pads put into the calipers. Purchased two months ago.
Just send me a PM.
2004 toyota 4runner v8 4x4.
Bilstein 5100, Toytec Superflex, toytec/elibach front lift coils, 1 inch toytec body lift. 17x9 Method The Standard wheels, 285/70/17 Cooper AT3's, LC80 Snorkel
derekdevasia is offline   Reply With QuoteReply With Quote
Old 05-26-2022, 03:55 PM #81
mcbru mcbru is offline
mcbru is on a distinguished road
Did the swap about a month ago on my 05 V8 with the small brakes. Some notes from my install.
Got 2012 4Runner calipers, rotors, and pads (should be same anyway)
For anyone not wanting to pay for OEM prices: in my experience Centric is the only non-OEM brand I would trust to use quality seals and pistons. I purchased OEM calipers from a supplier but UPS put me thru hell and got the Centrics instead.
Only difficulty was removing the passenger side caliper bolts that hadn't moved since 2005. Besides that, just bent the dust shield back a bit and didn't need to cut anything. Bleeding the brakes wasn't difficult solo, but probably worth doing again whenever you have the wheels off next time.
The slow 40x pedal pumping thing was a game changer. After doing the install and first drive I said dammit, I need to bleed the brakes more. But remembered about this and it took the brake feel back to where it should be. You can hear a particular noise and suddenly the pedal feel changes.
2005 V8 Limited 4wd - "Bruce"
Also: 2020 Miata
mcbru is offline   Reply With QuoteReply With Quote
Old 05-26-2022, 10:09 PM #82
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Can you elaborate on the 40x brake pedal pumping thing?
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 05-27-2022, 02:47 PM #83
Sure. Check out this post: https://www.toyota-4runner.org/1263477-post8.html
Long story short. Key off. Press and depress the brake pedal 40 times in a row. Do it SLOWLY, maybe holding the pedal down for 2-3 seconds and then up for 2-3 seconds. At about 20 pumps (it was exactly 20 for me) you will feel and hear a change. Do 20 more. Then you're done. Drive and enjoy.
Also: 2020 Miata
Old 05-28-2022, 07:23 AM #84
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I just pulled my Centric 5th gens that had been on for a couple years. Not impressed. I don't know if the lime and clay on the trails here in Fla were to blame, but the seals were pretty much shot.
I intended to rebuild them but one piston was seized enough to where soaking in brake fluid and using 110 psi back through brake line wouldn't break it loose.
Doing a LT project now so I'm putting 5th gen OEM calipers and shields back on w 5th gen "R1concepts" rotors and pads. Already done a mock up w Dorman hubs, everything fits fine.
Certain Toyota markets have been having sales w free shipping on orders over $75 lately. CODE: FREESHIP
Bought quite a bit of parts from Toyota of Melbourne Fla in the past several months and they've done a pretty good job.
5th gen Calipers (left)
(Right)
When buying a set of 5th gen parts for a 4th gen, your VIN won't work obviously, so dont enter anything, and they will send a follow up email (no VIN provided) you have to respond to, that you acknowledge you still want the parts, so they are off the hook for fitment issues and return shipping. Just make sure you confirm part numbers when you receive them.
I've saved a butt load on the sales + free shipping deal in the last 6 months. Got a brand new LC 200 steering rack for just under $450 from McGeorge Toyota when they had this same deal going back in December.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 12:28 PM #85
Skillz123 Skillz123 is offline
Skillz123 is on a distinguished road
Hi i was looking in to doing this mod as a calliper has sized up for the 3rd time hahah. Does anyone know if you get the core charge back if you give them back the wrong calliper? I guessing they probably wouldn't notice.
Skillz123 is offline   Reply With QuoteReply With Quote
Old 10-14-2022, 02:48 PM #86
ILL06V8 ILL06V8 is offline
ILL06V8 is on a distinguished road
I had the 5th gen front brakes on my Limited V8 for a couple of years now and I am happy.
I scored some rear brakes off of a new 5th gen 4runner, discovered the hub bore discrepancy as mentioned so I stuck with my OEM 4th gen discs.
One answer I have not been able to find anywhere is regarding the rear pads. Every post I've seen (including this one) claims they are THE SAME. However, the part numbers are DIFFERENT.
4th Gen rear brake pad kit: 0446660090
4th Gen rear brake pad shim kit: 0494630100
5th Gen rear brake pad kit: 0446660140
5th Gen rear brake pad shim kit: 0494660141
Visually, the pads are clearly made of a different material. The shims are quite different as well. It seems more logical to use the 4th gen pads with 5th gen shims on the 4th gen discs with 5th gen calipers but I couldn't be sure.
Does anyone know the REAL difference or have an answer for this? Thank you
ILL06V8 is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 01:30 AM #87
ace4aday's Avatar
ace4aday ace4aday is offline
ace4aday is on a distinguished road
ace4aday's Avatar
I just did mine with Powerstop Z36 pads and rotors. They list pads as the same part number for 2003-2022, if you buy them separately from the kits.
2008 Sport V6 in Salsa Red
Ironman 4x4 Stage 2 FCP Lift (2.5"/2")
Vision Manx II Wheels
275-70-17 KO2 Tires
Victory 4x4 Blitz Front Bumper
ace4aday is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 09:42 PM #88
fearnohardship fearnohardship is offline
fearnohardship is on a distinguished road
so i need to change my front brakes soon and thinking of going with oem rotors and ASP line of akebono brake pads.
does anyone think there will be an issue with this combo?
is it ok if i do just the fronts first than rears later ? also is it ok if the friction rating is different between front and rear or should i just change it all over.
not even sure what the rating of the oem ones are.
fearnohardship is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 07:58 PM #89
The aftermarket will probably just list the same part because they have the same pad material. I'm referring to OEM, bringing up the possibility of compromised compatibility between the different OEM pad/shim/disc combos. Obviously they will all work, but I would like to know why they use different materials for the different (at least dimensionally by hub bore) discs.
Top photo is for a 06 Limited
Bottom photo is 2010+ 4Runner/GX460
5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)-2006limited-jpg  5th Gen 4Runner Brakes Upgrade (for 4th Gen 4Runner)-2021-jpg
Old 01-27-2023, 02:31 PM #90
EnduringGuerila's Avatar
EnduringGuerila EnduringGuerila is offline
Real Name: Tim
EnduringGuerila is on a distinguished road
Real Name: Tim
Updated OP:
UPDATE:
Some people are still having issues with the calipers still seizing. This seems highly situational and I haven't taken the time to look for a pattern of causation.
I personally have had 0 issues and absolutely love the added stopping power. (Installed everything in March 2018 and it's currently Jan 2023)
and
My personal installation guide...
(didn't have time to document, bought PWR-KC138-36 and stainless braided Front and Rear lines)
2003 Limited 4WD V8 4Runner (Build Thread)
2008 CBR600RR (picture)
EnduringGuerila is offline   Reply With QuoteReply With Quote
brake , calipers , upgrade
Tundra Brakes vs 5th Generation 4Runner brakes. cbr400rr 4th Gen T4Rs 2 01-31-2016 02:13 AM
How much better do the brakes get with the Tundra upgrade? mirraman 3rd gen T4Rs 41 04-22-2015 02:26 PM
Brakes Upgrade <<<< 4th Gen T4Rs 4 07-25-2010 01:39 PM
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
