Old 01-13-2018, 10:15 PM #1
Toyoter Toyoter is offline
Toyoter is on a distinguished road
2WD Driveshaft removal
Hello,
I need some quick help with what I thought would be easy. '05 4.7 2WD, trying to remove the DS to do U-joints. Here's what we're working with at the rear section of the DS at the companion flange/pumpkin.
I can't get the nuts loose. I even tried an impact but they do not want to budge, not even an iota. IIRC, the torque spec is not considerable so they should not be that tough to remove. I initially tried to just remove the 14 mm nuts. I then tried opposing wrenches on the nut and stud (though there's no way an 8mm socket can compete with the torque of the assembly).
There's gotta be something I'm not doing correctly and I was really hoping to get this done tonight. Please tell me what you guys do to get these loose.
Also, does the factory use threadlock on those fasteners?
Thank you.
Toyoter is offline   Reply With QuoteReply With Quote
Old 01-14-2018, 02:00 AM #2
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
After putting a wrench on the nut use foot power. Lay under the truck, hold on to the wheel and use your foot. Don't laugh it worked for me on #1 & #2.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 01-14-2018, 03:42 AM #3
Real Name: Skip
Real Name: Skip
What kind of impact did you use, air or electric?
I agree on the foot power, work wonders, bigger muscles for more force.
You could also try a manual impact driver, the kind you hit with a big hammer, everyone should have one of these in their toolbox.
https://www.amazon.com/TEKTON-2910-2.../dp/B000NPUJYE
https://en.wikipedia.org/wiki/Impact_driver
2004 Limited V8
Old 01-01-2020, 05:46 PM #4
Davgolfer6 Davgolfer6 is offline
Davgolfer6 is on a distinguished road
Recently remarried and she came with a 2008 2wd 4Runner. Trying to replace front spline seal, but can’t get the driveshaft off. I removed all 4 bolts and pushed for to no avail. There is no center support to remove. I’ve tried turning the wheels to reposition, while trying to remove and nothing is working.
How do I remove the driveshaft after removing the 4 rear bolts. Thanks
Davgolfer6 is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 06:03 PM #5
weaves weaves is offline
weaves is on a distinguished road
There's a ridge on the flange of the driveshaft that fits into pinion flange that usually gets corroded. In most cases you can pry it off the pinion flange but if there's a lot of rust underneath then sometimes it needs a little more persuasion with a BFH or air hammer.
weaves is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 07:51 PM #6
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Prybar to move the DS forward a little and it'll drop off.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 11:28 AM #7
jackrabbit66 jackrabbit66 is offline
jackrabbit66 is on a distinguished road
Solution to remove driveshaft from stud bolts
I had to replace the Universal joint on my 2005 2wd 4.0 4runner sport edition 297,000 mile original driveshaft. After removing the 4 Nuts with a pneumatic impact wrench I was unable to pull the driveshaft forward enough to clear the stud bolts. I had the car in neutral with blocks under front tires to prevent from rolling and jacked up the rear end until the back wheels were off the ground. This helped with clearance a little but not enough to clear bolts. I decided the best option was to cut the ends off the stud bolts about 1/4". I used a dremel tool w/ cut off wheel and wore safety goggles & a welding shirt to prevent sparks from burning me or my clothes. I ended up only having to remove the un-threaded ends of two of the bolts before i was able to pull the driveshaft off. I didn't have any problem putting the bolts back on as i did not cut into the threads.
2WD Driveshaft removal-driveshaft-bolts-cut-1-jpg  2WD Driveshaft removal-driveshaft-bolts-cut-2-jpg
jackrabbit66 is offline   Reply With QuoteReply With Quote
FS: 4th GEN V6 4WD Driveshaft $100 used Redswan For Sale: T4R Items 0 04-15-2015 11:46 PM
Driveshaft removal Mellemel 3rd gen T4Rs 1 01-22-2015 09:47 PM
Question re: U-joints and driveshaft removal 92Pony 3rd gen T4Rs 7 12-08-2014 10:22 AM
Driveshaft Removal... Mel0 3rd gen T4Rs 31 12-17-2013 07:36 PM
help with driveshaft removal Jc12 3rd gen T4Rs 6 05-20-2012 11:59 PM
