Old 03-22-2023, 02:25 PM #301
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Got the rear shocks revalved and finally did a test run. Comp is way better and the rebound is more controlled.
https://www.youtube.com/watch?v=JjMOURhuJ5c&feature=youtu.be
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 03:06 PM #302
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Nice!
What are next for this thing as far as upgrades go for the near future?
awhitney1 is offline   Reply With QuoteReply With Quote
Old 03-22-2023, 03:27 PM #303
Real Name: Brett
Real Name: Brett
Originally Posted by awhitney1 View Post
Nice!
There are a couple things I want to try, but....I'm skeered to commit.
First: I have 14" triple bypasses I'd like to stuff in the back, and I extensively cycled it this last go-round to see if it would work, but I pussed out. Pretty sure I would have to cut into the cab for the upper shock mounts.
Second: I have a shift kit I want to try and do to the trans, which requires pulling the valve body out and apart, drilling some holes and upgrading springs, but I'm skeered....
Thirdly: I just got some URD goodies in the mail to try my hand at tuning.....
We'll see how skeered of that process I get....
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-maf500-1-jpg
Old 03-22-2023, 03:35 PM #304
I have the URD universal maf calibrator with a map preinstalled along with Yotawerx v8 tuner installed. Results are pretty good!
Be curious to see how the transmission shift kit will go. Any idea on what advantages a shift kit will do?
Old 03-22-2023, 04:04 PM #305
Real Name: Brett
Real Name: Brett
@Chad30 installed one in his trans and says the shifting has more bite to it now. I would like 1st-2nd and 2nd-3rd to be a ground pounder. It still boggs down a little in certain situations. Probably needs a lower gear too, but I want hwy ability also.
Since I have done so many engine upgrades already, Gadget just loaded the stock map. He doesn't have anything close to what I'm running. I would love for him to tune this thing but URD is 900 miles away.
Did we discuss the Yotawerx or something similar awhile back? I didn't think they had a non-vvt-i map available yet.
Old 03-22-2023, 04:14 PM #306
As far as I know, Yotawerx doesn't have a tune yet for the non vvt-i
Old 04-04-2023, 11:38 AM #307
Do you know what shift kit you are using?
Old 07-11-2023, 07:19 AM #308
Real Name: Brett
Real Name: Brett
Sorry my friend, I just now ran across your post smh.
It's a Ratiotek part# RT-A750E-HD
I was also advised to change the Pressure Regulator Boost Valve with a "TransGo" version.
Old 07-11-2023, 07:21 AM #309
Real Name: Brett
Real Name: Brett
A little Nitrogen love.
IMPROVE YOUR RIDE QUALITY - How to Check Nitrogen Pressures in your Off Road Shocks - YouTube
Old 07-11-2023, 12:23 PM #310
Thanks for the info! Whenever I do my tranmission, I want to do these upgrades!
Old 07-11-2023, 01:00 PM #311
Real Name: Brett
Real Name: Brett
I'm still pussin out on doing my transmission lol.
I'm gonna be out there next week in CO Springs for work. Wish I could drive....
Old 09-15-2023, 07:45 PM #312
Real Name: Brett
Real Name: Brett
Working on my heimlich maneuver.
Need a few more * caster.
Adjusted it once, drove to the tire shop and put it on the rack, still not enough.
Cracked em open and put a couple more twists on them.
Back to the tire shop 8am. I can feel the difference already, steering wheel input is lighter now.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20230915_114139-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20230915_130955-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20230915_114212-jpg
Old 09-16-2023, 07:47 AM #313
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Looks like a lot of work to make changes vs say, SPC.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 09-16-2023, 08:22 AM #314
Real Name: Brett
Real Name: Brett
Probably is, never even seen an SPC. Wouldn't have a clue how to adjust those.
This didn't take too long. I've got the removal/install of the uca bolt down to a few a minutes. Nothing else has to be removed except the tires.
Old 09-16-2023, 07:06 PM #315
Real Name: Brett
Real Name: Brett
Found some GX spindles awhile back. Rusted up pretty good, so they were cheap.
Gonna try to weld up some gussets. Need to spend an hour practicing on some scrap, cause I suck at welding lol.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20230916_184747-jpg
1UZrunner build page 1UZrunner Gallery 6 12-01-2023 10:49 AM
Ruggedly Elegant Golden Pearl Build RUGGED Elegance 3rd gen T4Rs 113 02-14-2023 01:00 PM
A10MileHusker's 4th Gen Build Page A10MileHusker 4th Gen T4Rs 247 07-17-2017 01:25 PM
Stell4R's Blue Pearl Build (really its for maintenance) stell4r 3rd gen T4Rs 29 07-13-2017 01:42 PM
Twelve1 build page twelve1 5th gen T4Rs 4 02-26-2014 02:41 AM
