Old 12-02-2023, 06:12 PM #331
4thGenCanuck 4thGenCanuck is offline
4thGenCanuck is on a distinguished road
Nice! Really like that bumper
4thGenCanuck is offline   Reply With QuoteReply With Quote
Old 12-24-2023, 04:12 PM #332
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Wide band installed. Next up is a URD tuning interface. Splicing it into the ECU harness has me a little apprehensive.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20231224_071656-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20231224_144124-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20231224_150947-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 12-29-2023, 11:50 AM #333
Real Name: Brett
Real Name: Brett
Decided to mount the URD in a location easily accessible. Did a base run on a Mustang Dyno.
I realize there won't be much more power gain out of this 4Runner in its current set up, but you gotta start somewhere. Thanks to Rolo Lopez @CentralFloridaTurbo It was basically a teaching session for him. As you can see in the video linked below, my dumb ass never went WOT on this pull...SMH. I had 3 bad pulls because of my inexperience, but I settled down on the last one and will use that as a baseline. I should have run 2 more.....
I do have to remember this MY only came 230 HP at the crank. They were made for more torque and these torque numbers on a Mustang Dyno aren't terrible.
Mustang Dyno You Tube Vid
03' 4Runner V8 w 35" tires
58* raining/intake Temps 70* to 90*
189.85 HP @ 4600 rpms
250.69 Ft Lbs @ 3900 rpms
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20231226_183100-jpg
Old 01-01-2024, 09:42 PM #334
Real Name: Brett
Real Name: Brett
RCF Throttle Body w one of Gadget's goodies.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240101_144319-jpg
Old 01-03-2024, 11:20 AM #335
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Does that URD throttle body spacer actually do any difference performance wise? Also, afraid that if I was to install a spacer, my cold air intake tube from AFE will hit the radiator fan.
awhitney1 is offline   Reply With QuoteReply With Quote
Old 01-03-2024, 03:42 PM #336
Real Name: Brett
Real Name: Brett
The spacer is actually an adapter to run a larger Throttle body off of the Lexus LC500/RC-F. Yes, you are correct, I had to do a little surgery to make it work for clearance.
I don't think there is any performance gain unfortunately. I think it's flowing a little more air, as the fuel trims changed a little, but until I learn how to tune......
I want to do some Cams w a port and valve job in the future also, so the larger TB should open things up, if I can pull that one off financially.
On the positive side is I have a brand new throttle body and it looks OK.
Old 01-03-2024, 04:22 PM #337
I figured you would have to do some surgery. Also have you looked into the Yotawerx tune?
Old 01-03-2024, 05:03 PM #338
Real Name: Brett
Real Name: Brett
As far as I know, they haven't developed a tune for the 03' -04'. I believe it has to do with Toyota going CAN bus in the 05' and later MY.
I think it's the current system protocol to date, across several models, so they have developed that tune first to serve a bigger demographic. Not that many 03' 04' owners looking for a tune I guess.
However, I might be able to clean up the fuel trims with the URD unit, so we'll see if I can get more power.
There are Piggy back and stand alone ECUs that work off of a Manifold Absolute Pressure system, which I may end up doing one day.
Old 01-05-2024, 09:35 PM #339
Real Name: Brett
Real Name: Brett
Transmission work this week. Got a mild upgrade on my valve body to firm up the spongy shifting. Also installed an 11" x 11.5" Hayden w 2 - 5.2" Spal pusher fans, switched out a few of the trans hoses, and put a Magnefine Trans Filter in line. . Truck is running good so far.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240104_122604-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240104_142923-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240104_142933-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240105_074713-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240105_165747-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240105_165754-jpg
Old 01-06-2024, 11:15 AM #340
Real Name: Brett
Real Name: Brett
FYI for everyone: Here is a video that John at IPT Performance Transmissions made using the valve body I purchased off Ebay and is the one I installed in the post above. I decided to roll the dice with this chinese reman, and I'm glad I sent it out for the service at IPT. The solenoids DID NOT MATCH my wiring harness, so I had to swap in my old solenoids. Truck worked fine last night on a 30 mile test drive, but I would say the Ebay Valve Body was a mistake.
What Did You Buy? Toyota A750- JUNK eBay "Rebuilt" Valve Body - YouTube
Old 01-08-2024, 11:21 AM #341
Thanks for the info! I may look into the IPT transmission upgrade!
Old 02-12-2024, 08:36 AM #342
Real Name: Brett
Real Name: Brett
Pearl finally got out of the swamp.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240211_154425-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20240211_154439-jpg
Old 02-12-2024, 02:39 PM #343
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
Hell yea man! Looking good!
2003 Limited V8 4runner - Slowly turning back to stock (until the next crazy idea comes along )
aemravan is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 04:14 PM #344
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
Regarding the Transmission VB upgrade...are you going to re-do the effort with an actual IPT upgrade? They do good work and certainly are a true shift-kit...Have you considered VFTuning for tuning or are you planning on dominating the scene yourself? nice work and it's always been a pleasure reading your posts!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 07:49 PM #345
Real Name: Brett
Real Name: Brett
Thank You!
I had John at IPT put their kit in that VB, although I think the converter needs upgraded to an IPT also. Still a bit slushy. I've beat this thing pretty good over the years, so it's time.
As far as tuning, we early 4th gens are at a disadvantage because of not being a CAN bus network. VF and the other tuners have focused on the Taco and 5th gen T4R for a larger demographic. They now have a tune for 05' and up 4Runners because Toyota converted them to the early CAN bus, which the tuners have learned over time. As far as I know, there aren't any readily available tunes for 03' 04'.
The URD MAF tune has helped, and I think there is more gains to be had, but my lack of knowledge and patience will hold me back lol.
1UZrunner build page 1UZrunner Gallery 6 12-01-2023 10:49 AM
Ruggedly Elegant Golden Pearl Build RUGGED Elegance 3rd gen T4Rs 113 02-14-2023 01:00 PM
A10MileHusker's 4th Gen Build Page A10MileHusker 4th Gen T4Rs 247 07-17-2017 01:25 PM
Stell4R's Blue Pearl Build (really its for maintenance) stell4r 3rd gen T4Rs 29 07-13-2017 01:42 PM
Twelve1 build page twelve1 5th gen T4Rs 4 02-26-2014 02:41 AM
