12-04-2020, 05:27 PM
#106
Real Name: Brett
Real Name: Brett
Originally Posted by montijo505
@ Inv4drZm
flexin a bit lol. Seriously though two of my favorite 4th gens on the forum.
Sent from my SM-G986U using Tapatalk
Thanks!! So far I have nothing on the flexing Kansan though. He wins big time in the mod and adventure categories. I might be in the running for the "oldest owner" category.
Originally Posted by Inv4drZm
Yeah, now make the rear axle match width-wise. Only way to roll.
No I won't be able to match that one. But I am getting 4:56s w an ARB, and with spacers My WMS to WMS will be 67" with this axle I bought of a guy in San Diego, and he is giving me his front gears once he pulls them out. What is your rear length by the way? I can't remember.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
12-04-2020, 06:07 PM
#107
69.895" WMS. Have you regeared yet? If not you will like the new ratio.
12-04-2020, 06:16 PM
#108
Real Name: Brett
Real Name: Brett
No I haven't, looking forward to it. Still haven't bought shocks for the front, and I would like to get new rear shocks to gain more travel, so I am trying to come to grips with that expense as well. I think I need to be committed.
06-12-2021, 11:59 AM
#109
Real Name: Brett
Real Name: Brett
@ xtremewlr
Hey Todd, Your truck is looking Great!
I finally might have some time to do this intake swap. Going through all the parts and comparing to your posts. I noticed two vacuum ports on the underside and see where you have them routed. The one in the rear loops out to the runner diaphragm and the other looks like it goes to the pressure regulator. Included some pics.
Just want to make sure where these hoses need to terminate. I see the regulator hose goes to the intake on my aluminum, and it looks like yours does also in one of your other pics.
Gonna go back and look at your thread on TW to make sure again what I'm looking at.
Also tried to find some diagrams in the service manual without any luck.
06-14-2021, 08:57 PM
#110
Real Name: Todd
Real Name: Todd
@ xtremewlr
Sorry for the slow response. Just got home from a weekend of wheeling and camping in norther AZ and up into southern Utah for a minute.
The rear vacuum line is exactly as I show in that pic there. The front one I ended up running the the vacuum port on the front passenger side below the intake. There's a dual vacuum port switch thing there (forget what it actually is right now) that has one line to the intake tube and another to the intake manifold. The regulator I used the stock vacuum port on the intake tube.
Edit: That S shaped hose on the top of the intake was only used until I got vacuum caps that fit.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
06-14-2021, 11:06 PM
#111
Real Name: Brett
Real Name: Brett
No worries, I figured you were out on the prowl this weekend. It's been way too long for me, but I'm glad to have a full schedule again.
OK I wasn't sure those were vacuum ports under the intake or not. The dual port switch on the front pass side is for the power steering power up feature I believe.
I spent the day with a dryer vent brush and some purple power cleaning the carbon build up out of the runners. Got it mostly smooth in there now. Had to gather up a couple more parts I forgot about, crush washers for the banjo fittings and an O ring for the coolant tube.
I might get this done sometime this year.........Gears, T-Case and LT are later this summer/fall hopefully. Still gotta find a Drive shaft guy as well.
Hope you had a good trip this weekend,
Thanks Todd!!!
06-15-2021, 07:35 PM
#112
Real Name: Brett
Real Name: Brett
Intake swap
Got the intake pulled. About a pound of sand under there.
Took awhile to get the starter out, serious PIA. Toyota engineers were gettin cussed this afternoon.
Never have seen an intake gasket like this one. Composite sandwiched between two metal pieces.
Noticed that the 05' Throttle body opening is almost 5mm larger in diameter than the 03'. Hope that equates to some Torque on the low end.
06-16-2021, 08:51 PM
#113
Real Name: Brett
Real Name: Brett
DUHHHH, ordered the 270cc injectors from Dirty Deeds w out getting the adapter connectors, so I won't hear it run for awhile lol.
Spoke w Keith just now and he confirmed the adapters will work w the 270cc on the 03'.
SMDH
06-16-2021, 09:05 PM
#114
Real Name: Todd
Real Name: Todd
SMDH
You can run it with your stock injectors until the others come in.
Why the 270cc injectors? Boost? I have the 250cc ones from DD and they are a direct swap, no adapter required.
06-16-2021, 10:01 PM
#115
Real Name: Brett
Real Name: Brett
I'm going on the road for 3 weeks so I don't need to drive it and still have the 13 mpg 5th gen lol.
No not gonna boost it.
I might be dreaming but I'm hoping with the 05' intake, Headers and Y pipe w 4:56 gears I will be gaining some torque with bigger injectors. Keith actually thinks it might be running lean as well so there is that.
I also was thinking of getting a MAF Sensor Calibrator from URD and maybe getting a little more out of it that way.
I know cost wise boosting is really the way to get power out of these Toyotas, but trying to get decent power out of N/A appeals to me. I'm probably dreaming though lol.
06-17-2021, 07:35 PM
#116
Real Name: Todd
Real Name: Todd
No, that makes sense. I forgot you had a real exhaust. I'm still running stock shit for now.
Can you post some pics of how the Antirock sway bar in the rear is mounted? It's something I've been considering doing to mine. Also, what length arms and width is it?
06-17-2021, 09:16 PM
#117
Real Name: Brett
Real Name: Brett
The picture above is of the axle I bought off Race Dezert from a super good guy in San Diego. It has Nitro 4:56s and an ARB locker in it with modified link tabs and lower shock mounts all set up for what I want to do with the LT. He made me a deal and got me a great price with his shipping dept at work. So I couldn't pass it up.
That pic is actually when it was still on his 4th gen, but he kept his anti-rock for the new custom build he was getting from Currie. He said the FJ anti-rock bolts right up.
Other than that I got nothing, except the part# label off the one I bought from Trail Gear. I hope to start this axle swap soon, but you know how time gets away from us. I'll try to keep you posted on how the Anti- Rock goes together, but hell the way you move, you might get to it before me.
06-17-2021, 11:00 PM
#118
Real Name: Todd
Real Name: Todd
This works just fine!
Things have slowed down for me. A little burned out on doing stuff to the 4Runner right now. I just want to enjoy it for a while and find what it really needs going forward. Like exhaust. The stock exhaust has been slowly ticking on cold start and seems to be getting slowly worse so I need to start thinking about the DT headers down the road. And gearing. And a rear locker. And a winch. And .........
07-08-2021, 08:59 AM
#119
Real Name: Brett
Real Name: Brett
Intake swap
Got Home Tuesday from 3 weeks out working, and the Injector connector extensions had arrived so I finished up yesterday.
Threw a P2103 code and it went into limp mode after a couple of minutes of idling-Throttle Actuator Control Motor Circuit.
I did not reinstall the coolant pass through that goes into the throttle body housing and had left the two ports open. So I capped them (red and yellow caps) and tapped lightly on the motor housing, thinking that the motor might have been stuck from sitting for several months.
The code was still registering in the ECU, but the engine had recovered from limp mode, so I had Torque Pro clear the code and went on a 15-20 mile drive and it seems OK for now. Will drive it for a couple days before I leave again.
Pretty generic picture because with a lack of time at home, and not much attention to detail like
@ xtremewlr
, I didn't paint anything like his great looking valve covers lol. This truck has always been more about function than form anyway. It takes quite the beating when I get out on the trails, so I just clean it mostly for maintenance purposes.
11-28-2021, 09:45 PM
#120
Real Name: Brett
Real Name: Brett
Finally got rid of the SR5 rims that came on the truck.
SCS Stealth 6 and some new KO2s.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
