03-16-2024, 08:31 PM
#347
Real Name: Brett
Real Name: Brett
This guy has some stones. Facebook
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
03-18-2024, 08:56 AM
#348
Real Name: Ron
Real Name: Ron
Originally Posted by 4RunnerAquasport
Yep, you have to be properly set up for that or you'll have some breakage! Your rig is probably pretty close I would think.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
03-18-2024, 09:06 AM
#349
it's wild to see these 4th gen bricks flying through the air lol .
pretty dialed it seems, though the front looks like it needs a little fine-tuning love. It's either bouncing hard off the bump stops, or rebound is too stiff. The rear looks pretty dialed on that trailing arm setup.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
03-18-2024, 08:14 PM
#350
Real Name: Brett
Real Name: Brett
It might be close, but it needs a cage for that much air lol. I really want a canoe style 4 link though.
03-18-2024, 08:25 PM
#351
Real Name: Brett
Real Name: Brett
Oh yea, he's blowing right through his travel and bouncing off the front bumps. I think it's a single CO. Needs some thicker compression shims and really a secondary shock for that kind of hang time.
Canoe style rear 4 link is bad ass.
03-27-2024, 12:59 PM
#352
Real Name: Brett
Real Name: Brett
Footage goofing around with the Drone.
AZ FILES ~ Drone/Go Pro Test - YouTube
04-21-2024, 02:43 PM
#353
Real Name: Brett
Real Name: Brett
Well the abuse has taken it's toll on Pearl. I know nothing of differentials. Anyone have an idea how bad this is? Doesn't do it in reverse and the ARB still locks up. Sounds like more to it than just a pinion bearing.
https://www.youtube.com/watch?si=7CT7J5ZsEwcxBK0U&v=yyLAOErHd9Q&feature=youtu.be
04-21-2024, 07:45 PM
#354
Real Name: Ron
Real Name: Ron
Sounds like a gear tooth may have broken off.
04-22-2024, 06:45 AM
#355
Real Name: Brett
Real Name: Brett
That would be impressive because they're Nitro gears and axles lol.
One too many jumps with my foot still on the gas I guess.....Frickin Rookie
04-22-2024, 08:35 AM
#356
if I had to put my money on it.. yea.. i'd say you busted a tooth or two on the ring gear. Unfortunately that's literally that sound I had in my supra when I blew the ring gear out of it..
I'm not a diff expert... but I would think/hope that if it is the ring gear it could just be a fairly "simple" swap out without having to re-shim and all... but may be more safe to also replace the pinion gear (unless that's what went to began with..).. it's hard to know what sort of damage the broken off material does in there once it's loose. If you haven't already, drain the fluid, you're bound to find some chunks come out..
on a more positive note... it looks damn good rolling out in the drone footage..
04-22-2024, 12:50 PM
#357
Real Name: Brett
Real Name: Brett
Yeah the drone thing takes some patience to drive the 4Runner and work the controller.
On another annoying note:
The seal in the ARB is puking oil out the solenoid up front. On my trip to AZ, I had to keep the compressor turned on so the pressure would keep the oil in the air line. So I may as well just start over with a whole new deal......SMH. Maybe look into an 8.2 out of a 5th gen.
It's weird that the diff makes no noise in reverse....
Yesterday, 08:16 AM
#358
that's very likely due to the way the gears are cut. It could just be a partial tooth break. I could be wrong.. but I would legitimately be surprised if the sound wasn't directly from a hurt ring gear.
