Old 02-07-2020, 11:30 AM #61
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Passenger side loose Woo Hoo! Progress!!
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-5-jpg
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 11:32 AM #62
Real Name: Brett
Real Name: Brett
So with the engine jacked on the passenger side I kept working on that side. First cleaning the heads with some emery cloth and then installing the Titanium studs.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-6-jpg
Old 02-07-2020, 11:33 AM #63
Real Name: Brett
Real Name: Brett
At this point I hung the gasket and loosely installed the pass header with a couple nuts.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-7-jpg
Old 02-07-2020, 11:34 AM #64
Real Name: Brett
Real Name: Brett
There a few of the lower studs that are hard to reach behind the runners and shock tower.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-8-jpg
Old 02-07-2020, 11:35 AM #65
Real Name: Brett
Real Name: Brett
So I thought up a little trick with some Gaffers tape and it worked pretty well.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-9-jpg
Old 02-07-2020, 11:37 AM #66
Real Name: Brett
Real Name: Brett
Next up was installing the dipstick tubes while the header is still loose. This one kicked my ass because for some dumb reason I tried to use the old path for the oil tube. I read the instructions, but it didn't sink in. You have to bend the tube quite a bit and at one point it looked like an old twisted up rope. It was late so I got some rest and with a clear head, my dumb ass realized the obvious path. So I bent the tube as straight as possible and started over lol. DT provides an extended mounting bolt and spacer that works pretty well.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-10-jpg
Old 02-07-2020, 11:38 AM #67
Real Name: Brett
Real Name: Brett
The driver side proved a little more challenging for access to the front bolt of the motor mount and a couple of the oem manifold bolts, as well as jacking up that side of the motor because of the differential, steering and accessories in the way. Everything worked out OK and the Sea Foam did it's job as well. NO BROKEN STUDS!!!!!!!!! All 16 came out pretty well. Here is the driver side as well as a clearance shot of the steering. Apparently there are some folks that have had some issues, mostly with the shorty tubes I guess. I don't see an issue here at all.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-11-jpg  Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-dt-12-jpg
Old 02-07-2020, 11:41 AM #68
Real Name: Brett
Real Name: Brett
I also don't weld so I drove it with open headers over to my buddies shop to have a couple things addressed on the rest of the exhaust. New muffler will be soon to come though. Here are a couple links for some open header phone audio clips. The selfie was unintentional because you know.....phoning and driving is illegal, especially with open headers.
[url=https://youtu.be/1CxD1GXcvaw]
[url=https://youtu.be/qLctYQZMPuo]
Old 02-08-2020, 09:18 AM #69
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Excellent tutorial on the header install, and great pics too. You should just leave the open headers, it sounds mean, lol!
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 12:52 AM #70
HanSolex's Avatar
HanSolex HanSolex is offline
HanSolex is on a distinguished road
HanSolex's Avatar
Man, your open header video makes me want to put these on ASAP. Am I wrong for kinda hoping my exhaust manifolds crack at some point here?
HanSolex is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 07:01 PM #71
Real Name: Brett
Real Name: Brett
Now I can Rock the decal.
Pearl's mod/build LT rear/DK +3.5 LT/Custom Baja Bumper/Thorley Headers/Manual T-case-20200209_092934-jpg
Old 03-04-2020, 11:56 AM #72
Real Name: Brett
Real Name: Brett
DT Headers, Y pipe, w Thrush muffler
Old 03-30-2020, 01:20 PM #73
Real Name: Brett
Real Name: Brett
Non essential
Old 03-30-2020, 05:19 PM #74
Real Name: Skip
Real Name: Skip
Originally Posted by 4RunnerAquasport View Post
Is that your suspension making all the rattling noises going over the bumps or did you have a can of rocks in the passenger's seat?
2004 Limited V8
Old 03-30-2020, 05:46 PM #75
Real Name: Brett
Real Name: Brett
LMAO! Well there are quite a few things rattling around. Most notably a high lift strapped down, with Tools and recovery gear strapped on top of it, and several odds and ends in the console and glove box. Speed in the whoops is always a noisy endeavor.
1UZrunner build page 1UZrunner Gallery 6 12-01-2023 10:49 AM
Ruggedly Elegant Golden Pearl Build RUGGED Elegance 3rd gen T4Rs 113 02-14-2023 01:00 PM
A10MileHusker's 4th Gen Build Page A10MileHusker 4th Gen T4Rs 247 07-17-2017 01:25 PM
Stell4R's Blue Pearl Build (really its for maintenance) stell4r 3rd gen T4Rs 29 07-13-2017 01:42 PM
Twelve1 build page twelve1 5th gen T4Rs 4 02-26-2014 02:41 AM
