06-21-2022, 01:41 PM
#226
Originally Posted by Inv4drZm
I meant it as a joke as the only way I see having both of those numbers is if the tire has a ridiculous amount of camber at droop.
I didn't even thing about it, I think you're right about that haha
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
06-29-2022, 01:11 PM
#227
Real Name: Brett
Real Name: Brett
Starting 3 weeks off, so it's Paint day on the frame and welded bits.
Decided to mock the seats up while the paint is drying on the frame.
Found a method on YT where you cut off the feet of the oem seats, and build your brackets off of them. Pretty sure I can use the Corbeau's Mustang bracket that they came with.
Looking to save the $300+ for the 4Runner brackets that they sell for their seats.
Once I have the frames built and I no longer need to mock the seats up, I'll dye them black.
Debating on how to proceed w the occupant weight sensors for the SRS. Splicing a resistor into the circuit is the easiest, but not necessarily the safest.
Won't need the 5 point harness for the hwy, so Im gonna retain the shoulder harness for now, and put the 5* in when I go offroad.
1988 DLX 22RE AUTO BLACK- "Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
07-01-2022, 03:37 PM
#228
Real Name: Brett
Real Name: Brett
Drivers side bracket fabbed up and painted.
07-03-2022, 11:14 AM
#229
Real Name: Brett
Real Name: Brett
The Corbeau sliders are mounted to the seat inserts w 5/16" allen heads, and then somebody mounted them to the frame w some weak little 1/4" kaka.
Now we have 5/16" grade 8 for those fasteners.
08-03-2022, 09:53 PM
#230
Real Name: Brett
Real Name: Brett
DK +3.5 Mock up #99
Well it's on the ground for a few hrs. Checking ride height and a couple other things. Because there is not much spring preload, I was able to find a way to adjust the C/O while still on the vehicle.
Still need the front drive shaft and brakes installed w dozens of little oddball things also. (MC cam gussets need zerk fitting clearance on the front 2 tabs).
Need to recheck all hardware and torque it down.
Gonna leave the fenders off for awhile until I do some shake down tests.
Just hoping I accounted for all clearance issues......
08-04-2022, 01:20 PM
#231
Getting exciting man! Can't wait to see this thing in action. It's amazing that it's possible to tuck away a dual shock setup upfront on these things. Looks damn good.
08-04-2022, 05:09 PM
#232
Real Name: Brett
Real Name: Brett
Seat Swap
The driver seat needs another coat of dye I think.
I've been slowly getting these brackets built. Still using the Mustang bracket for the passenger side as well. It will be close to the driver seat in height and pitch.
Full set of seats for sale cheap.
During the cooler mornings I've been trying to sort out this suspension. But when the Sun starts getting overhead, I mostly do all my cutting and grinding on the work bench in the garage w the shade. So that's when I been working on the brackets.
Laying on a hot driveway in 95* heat ain't much fun. My farmer tan is looking good though.
Zerk fittings are pissin me off. I think I have to take both sides back apart. Then remove the LCAs to clearance the cam gussets properly.
I'm gonna try and use a die grinder and a rasp to see if I can hollow out enough for the zerks to clear, before I tear it all back down...AGAIN.
08-06-2022, 12:50 PM
#233
Real Name: Brett
Real Name: Brett
Brake day
Always liked the look of new calipers and rotors.
OEM 5th gen calipers and dust shields.
R1 Concepts pads and rotors.
DK has a brake line system that requires a little forethought, which I didn't, so I'm sorting that out today.
Got the Zerk fittings figured out.
Had to cut a notch in the MC front cam gusset. I rotated the cams back and forth, and the zerk hitting would definitely have affected the alignment process.
Its not ideal but it works.
08-06-2022, 02:30 PM
#234
Real Name: Ron
Real Name: Ron
Yes, new brakes, suspension, arms and everything painted is definitely cool!!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
08-07-2022, 01:06 AM
#235
Awesome build thread! so cool to see all your progress and your 4Runner family. Keep up the great work and rad posts, thanks!
08-10-2022, 09:20 AM
#236
Real Name: Brett
Real Name: Brett
Feeling Truggy this morning
08-16-2022, 07:55 PM
#237
Real Name: Brett
Real Name: Brett
I at least got Pearl down off the jack stands and drivable before I had to leave for 2.5 weeks.
Hertz gave me the choice of a Tesla or a Gladiator (43k miles).
Obvious choice for me.
I can't say I dislike it, but I could never own it because of leg room. Fully adjusted seat has my knees a little over 2" off the dash lol.
Here in NJ its been all hwy, and once I got used to it (8 speed trans), I have to say I'm having fun with it.
Its got good pep but still has a little E-throttle lag.
But, If you've ever been to Jersey, there is alot of on/off ramps, and I been pushing this thing hard into the turns. I never thought it would handle as good as it does. The Fox susp is pretty well tuned.
Would love to hit a trail or two, although doubtful in north NJ. I have hopped a couple curbs....
08-16-2022, 09:43 PM
#238
Real Name: Ron
Real Name: Ron
It's just an ugly vehicle IMO. I have seen some on bigger wheels and an enclosed rear that do look better, but stock ... uggh.
08-17-2022, 06:35 AM
#239
Real Name: Brett
Real Name: Brett
Oh yea, its hideous looking lol. No argument there.
08-17-2022, 02:50 PM
#240
in a stock form its probably one of the more uglier rigs on the road lol. A little lift and some 37's go a long way with those. I don't think I would ever own one.. just because it's not really a jeep or a truck, therefore it must do both only somewhat OK.. you either get a jeep or you get a truck.. lol.
Glad to see Pearl off the stands and under its own power man! Definitely have made some good progress over the past few months.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
