I'd got with the Daystar 2.5/1.5. That is what I originally did when I put 265-70R17 tires on mine. Only thing I had to do was moved the fender liners forward because of minor rubbing. Also, if you are going with the Toyota TRD Pro wheels I'd throw a set of 1.25" Spidertrax wheels spacers on, will give you a more aggressive look.
Daystar? - Driven by Design
Toyota Hub Centric Wheel Spacer Kit
Here is mine with that exact setup.
