Originally Posted by Drunner97
^ This. It was likely your ATRAC working with the tires that were slipping. If you had kept the RPMs right around 1500-2k it probably would have pulled you right out, but I'm guessing you were letting off the gas each time it did it. I've had ATRAC pull me right out of sloppy mud and wet ice/snow, but it takes a little bit of sitting in place until it can figure out which tire has traction.
Okay so that makes sense and is more understandable, this was my first encounter with being stuck off road in my 4runner since I bought it
I was unaware that the ATRAC system worked like that because it sounded exactly like the vsc/traction control does when I start sliding in an icy turn or something
Thanks for the input!
After this experience I’m thinking I may invest in some max trax anyways just so I can be even better prepared
