02-23-2018, 01:14 PM
#16
Real Name: Sam
Real Name: Sam
Originally Posted by Drunner97
I'll measure for you this weekend once I get the rig unloaded completely since I'm not running a body lift and they got some break in time on the dirt. I am running a 200 lb steel bumper with full size 35 on the swing out. With the 2" medium coils I sagged about 1/2-1" after I put the bumper on. I expect once the heavy coils finish settling I'll end up with roughly a 2-2 1/2" lift fully loaded.
which is exactly the height i want.
Here is the 2" on 35s with a 100lb tent on top loaded down with camping gear.
just under 2"
02-23-2018, 01:17 PM
#17
Thanks everyone- looks like I'll be getting the HD springs. Anyone run them with OME 60071L shocks? 15.25/26.5" seems like it should work without dropping the bumpstops.
Also, is everyone keeping the rear sway bar? I know it limits flex, but my 4Runner is a daily driver/kid hauler. Might keep it on most of the time and ditch it for burlier trails.
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
02-23-2018, 01:19 PM
#18
Real Name: Danny
Real Name: Danny
Only side pic I have with me but it was after install and I actually have a jack under the driver side LCA so the passenger coil is slightly compressed.
Sent from my Nexus 6 using Tapatalk
02-23-2018, 01:20 PM
#19
Real Name: Sam
Real Name: Sam
i dont have any sway bars on mine, and it is tippy, especially with the tent. I would try with it first. Then disconnect and test it out without it and see what you think.
Some like it, some dont.
02-23-2018, 01:22 PM
#20
Real Name: Danny
Real Name: Danny
I'm just running regular Icon 2.0 with remote resi extended travel shocks, not the Metal Tech specific shocks. Can't comment on OME stuff.
Haven't had a rear sway bar in a couple years, although I almost wish I'd had it driving home in 40-50 mph winds last weekend. I was all over the road after trashing my front end alignment.
02-23-2018, 05:09 PM
#21
My brother has those shocks on his FJ. Freaking stiff. The FJ is short too so it feels like a constant front to back motion, the rear overpowers the front. He has stock weight in the back daily, just skids/sliders/roof rack if those count. Loaded down a bit more they do ride better of course. I wouldn't put them on my truck as a daily driver but they do have nice travel and are cheap. Noticeably stiffer than my 2.5" Icon rears and his previous 2.0 Icon rears.
02-23-2018, 05:53 PM
#22
Good to know. I have OME up front so I'm trying to match the feel of those. I currently have the 60020 rear shocks and they are firm, but not terrible. ARB lists a 60020L shock (14.9/26.5)- not sure how they cram that much travel in such a short compressed length.
02-24-2018, 02:12 PM
#23
02-24-2018, 03:06 PM
#24
Thanks, Chankeye. That does look like more than 3”! How much weight does it take for the rear to settle down a little?
Your 4runner is looking good. It’ll be interesting to see how much lift you get with the medium springs.
02-24-2018, 04:25 PM
#25
Real Name: Danny
Real Name: Danny
I'm about 25" both sides. It's hard to get super accurate because my sidewalls bulge out so far.
This is mostly unloaded, just the bumper weight.
02-24-2018, 04:51 PM
#26
That looks perfect. 25” is what I’m looking for. How much does your bumper with swingout weigh? 250-300ish?
02-24-2018, 04:55 PM
#27
Real Name: Danny
Real Name: Danny
About 200, then the wheel/tire combo is like 80ish.
02-24-2018, 05:08 PM
#28
i've only had about 300 lbs in it and the back dropped less than .5 inches. i can see having full skids, steel bumpers, and being loaded with gear dropping it significantly, to the point of being perfect (to me). that's why i'm going to hang on to the heavy springs and run the mediums for now. thanks for the compliment though, i'll be installing the mediums today so i can get back later with a pic of what those look like.
10-01-2019, 11:10 AM
#29
just under 2"
So after reading through it seems that it's totally fine to run these springs with the standard icon 2.0, part# 56505 shocks?
Would you reccomend the medium or heavy coils with 50# of tools, rear drawer system, 100# roof top tent. I'll be eventually adding a custom tube swingout.
10-01-2019, 02:32 PM
#30
Real Name: Sam
Real Name: Sam
go with the heavy, i swapped to the heavy and its been great with the weight.
