Real Name: Chris
Real Name: Chris
Service both diffs and transfer case. Check sway bar end links and frame bushings. Check all tie rod ends and ball joints. Changing geometry after so many miles can sometimes cause steering and suspension parts to fail shortly after simply because they have worn the same way for so many years and are now in a totally different position. Just check every moving part now and continue to check every oil change which really should be done anyway.
