03-14-2018, 01:22 AM
2008 4Runner owners, assemble.
Gents,
Looking for some help. If any of you like train wrecks, check out my dead 4Runner thread. And I know if there’s anything this forum needs, it’s more threads, so here goes. I have an interesting theory on why my 4runner may be messed up and have a theory about a potential change in ABS/Skid ECU in the 2008 model.
If you guys happen to have an 08, can you take a look at the ECU next to the brake fluid reservoir and let me know if your model number mactches my used one, or if your ends with a ‘51’. Or something different. I’m particularly interested in if you’ve got a 4WD model as well.
Model number I’m interested in is under the word “ADVICS”
Thanks
Air 4rceRunner One, 04 Sr5
03-14-2018, 01:47 AM
My number is 89541-35051 yes it’s 4WD.
03-14-2018, 11:29 AM
Mine is 89541-35051, 4wd SR5
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
03-14-2018, 05:17 PM
Thanks guys! I really do appreciate you taking the time to help me out. It’s weird cause the brake master cylinder assembly is the same part number 05-09, but it certainly looks like the ABS/Skid ECU is slightly different.
03-14-2018, 06:09 PM
Sport 4WD
My number is same as others above. 89541-35051
03-15-2018, 11:13 AM
So what is your theory? Wonder what the difference is between the 2 computers...
03-15-2018, 04:56 PM
Real Name: Danny
Real Name: Danny
Sounds like there might be, and I'm betting that's because there's a VSC off switch for the 08-09 and if that's the case I wonder if you can change the computer on a pre 08 to get access to that VSC switch without doing a wire cutting mod.
03-15-2018, 05:05 PM
2008 4R Limited 89541-35051
2008 4R Limited Salsa Red Pearl 3Q3
AVS Bugflector, Coastal Lockpick 2, Super Z V1 Radar Detector Mount
Please, no more Hope & Change!
03-15-2018, 08:22 PM
That’s exactly my thought. It would explain why my VSC off switch doesn’t work with my new master cylinder assembly. Although I’m not sure why my 4runner wouldn’t secure the VSC when I lock my center diff. Unless somehow the VSC off switch is somehow tied into that in the new system. I’ll figure it out in a week or so!
03-16-2018, 03:44 PM
I realize you are looking for 08, my late 07 SE is 89541-35050 if that helps.
02-22-2019, 01:51 PM
Simple
Mine is 89541-35051, 2008 SR5 4WD
and look what I have going on: 2008 4Runner Parking Brake Warning Light & ABS Light Flicker Simultaneously
I'm starting to think my issue lies within the ABS/Skid Control ECU.
Looks like it would be important for me to ensure I replace it with the 89541-3505 1 vs. 89541-3505 0 based on what your saying about the 08-09 having the VSC OFF switch.
What was your final outcome and why did you replace your master assembly to begin with?
Joe Santoro
4th Generation - 2008 4Runner SR5
02-23-2019, 02:32 AM
Originally Posted by sant6236
Simple
Hey man, I’m sorry you’re having issues. I ended up having a freak electrical problem after leaving my car parked for a few weeks with a parasitic drain issue. I tried to jump my car several times with a jumper pack but it didn’t do it. Used cables, and I swear I didn’t, but I likely crossed the cables which fried my ECU. My brakes were no longer powered, I had a continuous buzzer, and I had to stand on the breaks to get marginal (at best) braking power. I couldn’t get an ECU without the master assembly so I did the whole thing.
After installing the correct ECU I haven’t had any issues. To be fair, the old ecu worked well minus the VSC Off functionality. Though, I’m not sure what the overall functionality of the VSC system as a whole was either. I drove for about a week with the wrong ECU, but I was nervous that the VSC would randomly kick while I’m on the freeway or something, or not kick off with a loss of traction. Not worth it, if you’re going to replace it, get the right one if you can.
02-23-2019, 10:51 AM
For what it's worth, 2008 SR5 2WD and it ends in "51"
02-23-2019, 04:09 PM
Did you go Used or New on the MC Assembly? And did you install it?
Joe Santoro
02-23-2019, 04:32 PM
Real Name: Scott
Real Name: Scott
So I randomly happened onto this thread and it has me wondering: for those of us with 06-07, will this give us VSC off capability? And does the wiring harness already have a connection to plug the switch into?? Where is the VSC Off switch on the 08 and 09?
-Semper Fi-
2006 4Runner Sport Edition 4WD V6/Suspension/Armor/Lights/Wheels and tires/Drawers/Camping things/Surfboards/Rhodesian Ridgebacks . . .
BUILD AND ADVENTURE THREAD
