First question you really want to answer is “What is the amp draw of the GPS unit?”
You could just use the map light circuit itself but I would make sure you don’t exceed the design limits of that circuit.
Map light circuits are generally always on, so you could just get a fuse tap off the accessory circuit which is ignition controlled and run the wiring up the pillar to where you want it.
