Old 07-10-2020, 04:56 PM #46
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
Originally Posted by BrunchKing View Post
I have a 2007 4Runner that has ran great for the last 165k miles. Now my Trunk wouldn't close randomly. I bungee corded it closed, assumed it was the actuator motor, and bought one off amazon ( Amazon.com: Genuine Toyota Parts 69110-35090 Rear Gate Latch - 69110-35062: Automotive ) Now the hatch will close but not open. Any ideas? The back window still goes up and down if that helps. TIA.
There’s a lot of little tricky combinations of things to try. I’ve had to lock/unlock my driver door 3 times and it did work A few times. Another time it didn’t and had to unconnect/ reconnect battery. The last time I tried everything except for disconnect blue harness into the Ecu for it. I rolled the rear window down by holding down button, and rolled back up holding a couple seconds after it closed and mine reset. Initially my hatch wasn’t closing though, the button just wouldn’t unlock when pushed. If none of that works you may want to double check and make sure the button is working and powered.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 07:29 PM #47
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
They rust and seize, mine is currently down too, actuators are on international back order
Flybynight is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 04:03 PM #48
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
They might have one or a few in stock here...
Trunk Lock Actuator Motor - Toyota (69110-35090) | Toyota Parts
Usually if they don't have it in stock it says "unavailable" or "back ordered" but i't's possible their website hasn't been updated recently.
2004 Limited V8
Old 07-13-2020, 02:48 AM #49
Flybynight's Avatar
Flybynight's Avatar
Thanks, wouldn't let me buy one though
EDit - found one on ebay $245 CAD (versus $381 locally). Ordered!
Old 10-03-2020, 07:52 PM #50
shusted shusted is offline
shusted is on a distinguished road
I have been reading through this thread today because about 1 week ago my hatch would not open however the rear window does roll down. When I try to open the rear hatch nothing happens, no sound, nothing. I did what others suggested and disconnected the battery. This fixed it for a few days and then the issue returned. It seems that most on this thread then move to replacing the hatch motor which is roughly $250. Would replacing the hatch motor be the logical next step?
Thanks for the help
shusted is offline   Reply With QuoteReply With Quote
Old 10-04-2020, 12:01 PM #51
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
These guys have the actuator for $130, +$10 for shipping.
They sell out pretty fast. Out now but they seem to restock often.
Tailgate Actuator for Toyota 4Runner Back Door Trunk Hatch Actuator 2003 - 2009 | eBay
I picked one up a couple months ago, works good.
Whoa, down to $99 now
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 04:50 PM #52
Dfall00d Dfall00d is offline
Real Name: Dylan Fallin
Dfall00d is on a distinguished road
How did you get the tail gate open to install the actuator? I can’t get the back panel off without opening the trunk door
Dfall00d is offline   Reply With QuoteReply With Quote
Old 10-31-2020, 05:40 PM #53
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Dont have to open to get at it.
Take the interior plastic cover off.
One bolt holds the pull handle.
That cover just pulls off, start on a bottom corner. Pull towards inside.
Then the top edge at the window scraper lifts up.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 04-15-2021, 05:04 PM #54
magosusa magosusa is offline
magosusa is on a distinguished road
I bought the latch actuator from eBay and although it worked, it's just like before. My symptoms are:
- Can't open the back door with the key off (even if unlocked)
- Rear window will not roll down with key or FOB (the manual switch on dash works)
- When the key is ON, I have to unlock 3 times for the back door to open and close properly.
I've checked all the connections, cleaned them with electronic contact cleaner. No visible rust or bad grounds, everything looks to be in good condition. Any suggestions out there?
Thanks all!
magosusa is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 12:17 PM #55
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
MagosUSA.
Your issue sounds like an electrical issue. How good are you at testing with the factory service manual in front of you?
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 04:52 PM #56
Piggity Piggity is offline
Piggity will become famous soon enough
Thanks all!
Sounds like you need to do the relearn on the rear window. You have to press and hold the rear window button down till about 10 seconds (could be 5 idk) after it bottoms out and then do the same for the top. If you do a search on here it should come up with the procedure.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 06:21 PM #57
LOSTR4's Avatar
LOSTR4 LOSTR4 is offline
LOSTR4 will become famous soon enough LOSTR4 will become famous soon enough
LOSTR4's Avatar
I worked on installing a momentary-switch to release the rear hatch when inside...the directions are/were easy enough but since tapping into the Body-ECU, it would only lock when the button was pressed...so I removed the t-taps and re-inserted the harness connector into the Body ECU and now nothing works...I got the hatch to lock but it was all manually done...what am I missed? I tied into the green with red stripe and the purple with white stripe...now that I look at the ECU harness wires, there are two purple with white stripe wires...I tried the other one too with no avail...any suggestions?!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
LOSTR4 is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 03:52 PM #58
MikeinNH67's Avatar
MikeinNH67's Avatar
I see some others under $70, I might try one of those out at that price. I open mine with a hard wires toggle switch.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 08-11-2021, 02:35 PM #59
drallan drallan is offline
drallan is on a distinguished road
I purchased an $80 actuator off eBay and its been working for 6 months no issue. My problem started intermittently, rear hatch wouldn't open on random days, then it slowly got worse and worse. To the point where the only way to open it was to disconnect battery for a few sec, then reconnect. For some reason it would reset and allow me to open once or twice, but then lock up again.
Took about 20 min to swap out and was pretty straight forward.
drallan is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 06:26 PM #60
Wizzalsh13 Wizzalsh13 is offline
Wizzalsh13 is on a distinguished road
Same issue on my 06 4runner
Hey just came across your thread and my rear door is having the same issue. Window works fine but the button on the door to release that latch won’t work. Do you remember if you just replaced the whole lock actuator assembly and that fixed it? Or did you also need to do anything with the button switch itself?
Wizzalsh13 is offline   Reply With QuoteReply With Quote
Help!!! Rear hatch won't open. drtdvl 4th Gen T4Rs 170 07-26-2020 05:11 PM
Rear Hatch Won't Open.... Twins114 4th Gen T4Rs 4 11-27-2013 11:13 AM
No way to open rear hatch with key? MeBe4running 5th gen T4Rs 24 10-22-2012 10:35 PM
Rear Hatch Won't Open.. Ameritimer Problems & Warranty Issues 0 04-12-2011 08:50 PM
