Old 04-13-2018, 01:34 PM #16
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Not sure of your budget
but you might consider the 2.5" diameter bilstein 6112 strut with the available 650lbs rated spring. no mixing/guessing and predictable calculated results...
jrm is offline   Reply With QuoteReply With Quote
Old 04-14-2018, 10:45 AM #17
vonguido vonguido is offline
vonguido is on a distinguished road
How does that spring rate compare to the 885? Does the 650lbs spring come standard or is that another cost? Part number with the heavier spring? I agree a 2.5” shock would be better.
vonguido is offline   Reply With QuoteReply With Quote
Old 04-14-2018, 12:07 PM #18
jrm's Avatar
jrm jrm is offline
jrm jrm is offline
jrm's Avatar
well
Check the ARB application guide available on the internet for the 885 spring rate. Cant tell you if theres an additional cost/PN since i have the 600 lbs coils on my 6112s. Google should yield you some results on the subject. Good luck..
Old 04-14-2018, 08:11 PM #19
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
The 885 is 590lb
I also would have gone with the 6112's if they had an spring option other than 600lb that didn't cost extra. Or if you could just buy the shocks alone . I didn't want to fork out another 170 bucks for springs to help with the bumper and winch.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 04-15-2018, 03:19 AM #20
Originally Posted by Rodtheviking View Post
The 885 is 590lb
Good to know, thank you.
Old 05-28-2020, 03:38 AM #21
Gkhuang's Avatar
Gkhuang Gkhuang is offline
Gkhuang is on a distinguished road
Gkhuang's Avatar
OME + 5100's
Hey guys, newbie here.
I have an 07 v6 and just ordered Bilsteins all around with OME springs @ 884(f)/895e(r)...
Throughout t4r.org, I have read that this combo will either level out my the vehicle or give it a negative rake. Read another comment saying that 895e's are not meant for 884s but rather 883s. Other say that it works well, but maybe for v8's? Should I be changing my order or is this combo ok? Thanks in advance.
Gkhuang is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 04:00 AM #22
Nahrah's Avatar
Nahrah Nahrah is offline
Nahrah will become famous soon enough Nahrah will become famous soon enough
Nahrah's Avatar
I'm running the same setup on my 07 v6 Bilstein all around with 884 in the front and 859e in the rear. Barely any noticable reverse rake, I can say its almost leveled after its settled and rides pretty nice.
Current - 21 TRD ORP, Method 316 on 285/75/17 Toyo MT, Bilstein 5100’s OME 885/889, Spc UCA
Old(still in the family) - 07 Sr5 V6 2wd, Bilstein 5100's, Ome 884/895e, TRD ORP wheels, SPC UCA and CBI front skid plate.
Nahrah is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 01:29 PM #23
Gkhuang's Avatar
Gkhuang's Avatar
Thanks Nahrah.
I noticed you got UCA's for the set up. I didn't go that route..yet. Were the angles too far off OEM specs?
Old 05-31-2020, 11:48 PM #24
Nahrah's Avatar
Nahrah's Avatar
Thanks Nahrah.
I installed everything at once, so I wouldn't able to tell you. But my alignment were back to oem spec, plus I'm running 285's and barely any rub.
2nd GEN Tacoma Bilstein shocks and springs Hanau 5th gen T4Rs 2 10-29-2013 07:44 PM
FS: Bilstein strut/shocks & springs ronsta For Sale: Suspension/Wheels/Tires 10 04-20-2012 10:42 PM
Stock FJ bilstein shocks & springs MaliciousClout 4th Gen T4Rs 4 08-06-2011 01:10 PM
