Originally Posted by jrm
but you might consider the 2.5" diameter bilstein 6112 strut with the available 650lbs rated spring. no mixing/guessing and predictable calculated results...
How does that spring rate compare to the 885? Does the 650lbs spring come standard or is that another cost? Part number with the heavier spring? I agree a 2.5” shock would be better.
