12-11-2019, 05:14 PM
#16
i just dropped in a KN recently and i thought i could feel it mid to high rps a bit more, anything i can get. thank god not the 5th gen v6, heard theyre dogs!!
12-11-2019, 05:16 PM
#17
Real Name: Elliott
Real Name: Elliott
Originally Posted by cali2008
Found this interesting youtube link experiment on air filters:
YouTube
A few things worth noting here:
1. This test was done using drop in filters in the stock air box versus an aftermarket air train designed to increase flow to the throttle body
2. No other modifications were actually done in this test, and still the high performance filter did produce slightly more power and acceleration
3. The real gains can only be realized when you replace the MAF with one that has different mapping to make use of the increase in air flow. The throttle body spacer I feel is questionable as far as effectiveness, however anything that can help the engine breathe better is going to make a difference, so in theory it should help.
That was an interesting video nonetheless. Thanks for sharing it with us!
@ BlackWorksInc
I can confirm on the Spectre unit I have, no whistle at all. Bizarre that some do and some don't. Not sure it matters, honestly
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-11-2019, 05:18 PM
#18
Real Name: Elliott
Real Name: Elliott
I've heard the same. Different mapping and I know they made some minor changes to the engine layout, not sure what those were. I know
@ GChristo
has commented to me irl about this as well.
