04-22-2018, 05:25 AM
#16
Real Name: Jimmy
Real Name: Jimmy
Originally Posted by AuSeeker
Coolant hoses, I would think any transmission hoses are OK, but I would at least inspect them for posible dry rotting/cracking, and yes I always replace the spring/tension type clamps with the screw type.
So, as long as we're on a roll, should I use Toyota hoses or what? Thanks for all the help. I'm ordering everything I heed today.
2003 SR5 V8 2WD, Borla Exhaust, Volante Intake
Stebel Truck Horn, All LED Conversion, Map Light Mod
2014 Scion Touch Screen Radio, Lexus Steering Wheel
Lexus Shift Knob
04-22-2018, 08:07 AM
#17
Real Name: Skip
Real Name: Skip
I don't think OEM for the hoses is necessary, but that's up to you.
2004 Limited V8
04-22-2018, 12:28 PM
#18
Real Name: Jimmy
Real Name: Jimmy
Thanks so much for your help.Ii have ordered a Denso radiator from Amazon and OEM hoses from Partznet, who I often use. Price was insignificant on the hoses. Amazon was cheaper than RockAuto after prime shipping. Thanks again!
Lexus Shift Knob
03-28-2020, 09:29 PM
#19
Had the same thing happen to me today. 2003 Limited V8. I had driven it about 5 miles to work, maybe 10 minutes driving, parked it and turned it off. About a minute later I hear a splashing noise and the radiator dumped coolant out of the top hose, which had popped off at the radiator (it's the outlet hose from the block to the radiator). I double checked to make sure that the truck wasn't hot, and it wasn't, temp gauge was exactly where it's supposed to be. Well, I picked up some new hose clamps and will put one of those on and top off the coolant reservoir before heading home, and then go from there. Planning to replace the entire radiator and all hoses on my next day off.
Before anyone asks, the thermostat is brand new so there's no way that was the problem. If anybody has any other ideas, thanks in advance!
03-28-2020, 10:02 PM
#20
Real Name: Todd
Real Name: Todd
Did you install the thermostat with the jiggle valve at the 12 o'clock position?
Be sure to use new constant tension clamps and not parts store worm gear clamps. The CT clamps from Toyota are cheap and work WAY better than the worm gear clamps.
Part number in the pic, you need 4.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
03-29-2020, 06:52 AM
#21
Real Name: Danny
Real Name: Danny
Just a couple thoughts here. First, I don't really see why everyone is immediately jumping on the thermostat as a likely cause here. If it was stuck closed it would be running hot, without question. But the OP said it wasn't. It might be as simple as the deterioration of the plastic on the radiator neck. And if some of it was broken off in the hose, yes it definitely needs to be replaced along with the hoses and a thermostat for good measure. But, my advice would be to keep a close look on it after all that is done. My first thought when I started reading this was, head gasket blown between combustion chamber and cooling jacket. That would be pumping compression into the cooling system and the extra pressure could have blown the hose off. But, I went back and reread the OP and saw that this is a V8, so it's not nearly as likely. But it's still a possibility. Under these conditions it could have excessively high pressure in the cooling system without running hot if it hadn't been driven very long. My point is, after you've done all the repairs, keep an eye on it. Or have it checked just for good measure. Good luck. I hope my suspicions are totally unfounded.
03-29-2020, 12:45 PM
#22
Real Name: Todd
Real Name: Todd
Keep in mind this thread was started in 2018 and the OP never posted if replacing the radiator and hoses fixed his issue or not.
@ jamesewells
, if you still frequent the forum, maybe post an update to this?
03-29-2020, 07:58 PM
#23
Real Name: Danny
Real Name: Danny
@ jamesewells
That's pretty funny. I usually check for that. Oh well, I guess we'll never know.
03-29-2020, 09:58 PM
#24
Since I revived this thing yesterday, here's my situation... My truck literally had a "new" (156K) motor installed last week, because I blew the motor a month ago. When the motor blew up, the same hose was popped off but it overheated really bad on the highway and then the truck died before I could pull over. Fast forward a month, I've got my truck back with the "new" motor and 50 miles in the dang hose pops off again!
It's done it twice to me now, each after about 10 minutes of driving. I went ahead and bought new hoses, new clamps, and a new radiator today at Advance Auto, and I'll be replacing all of that tomorrow and putting in fresh coolant. I don't know what thermostat the shop used, but I really doubt the thing went bad in 50 miles or less lol. Also replacing the pressure cap just in case.
My buddies are stumped, we figure it has to be either a plugged hose or plugged radiator. What I don't get is that the shop ran it at idle for three hours before picking it up, and drove it 30 or so miles, and it was fine.
03-29-2020, 10:11 PM
#25
Real Name: Todd
Real Name: Todd
Before you install the hoses back on, pull the thermostat housing and make sure the thermostat jiggle valve is at 12 o'clock. And order the constant tension hose clamps from toyota.
04-01-2020, 04:46 PM
#26
Real Name: Danny
Real Name: Danny
I'd be curious if the inlet neck on the radiator was still intact, ie, is it all there and does it still have the bulge on the end of it. If the end part with the bulge has broken off it would be very easy for the hose to come off. Ideally I'd want to put a pressure gauge on the radiator and see how high it's going. Replacing the pressure cap is a good idea. If it does it's job the pressure should never get high enough to blow a hose off. Let us know how it comes out.
04-01-2020, 07:04 PM
#27
Update:
Monday I replaced the radiator, both upper and lower hoses, thermostat and pressure cap. Seems to have solved the problem, I'm at about 60 miles driven since with no issues whatsoever. I believe the problem, as the post above this mentioned, was the "inlet" part of the radiator where the upper hose is clamped, the one which moves coolant out of the block and back into the radiator. That part of the radiator was badly corroded, a white/gray color, and had no more lip for the hose clamp to grab. A buddy of mine thinks that it could have been ruined when the truck overheated, probably by the PO. Especially when compared to the radiator outlet on the lower hose, which was still in good condition and had a lip, this seems to have been the issue. I'll try to post some comparison pics for anyone else once I figure out how to add them.
Thanks for the help y'all!
04-03-2020, 10:01 AM
#28
Real Name: Jimmy
Real Name: Jimmy
@ jamesewells
It fixed my issue because the neck on the radiator had broken.
Lexus Shift Knob
04-05-2020, 05:56 PM
#29
On the same note, what kind of radiator pressure are y’all seeing on the 2UZ motor? As far as “squeezing” the hose when motor is hot goes, my upper and lower radiator hoses are pliable but feel like they’re holding more pressure than I’m accustomed to, and more than my buddies V6 Tacoma that I was comparing to.
I drove it for an hour today on the highway with no issues and no overheating, just feel like it’s holding a little too much pressure.
