Originally Posted by Stunna1019
If I only remove the main cats and leave the secondaries will it tend to clog the secondaries quicker?
Not necessarily. A clogged cat is usually not too common unless there is another underlying issue that is causing it such as excess exhaust burn off or carbon being built up there. If you remove the main cats, you’re removing them from doing their job of keeping everything else cleaner behind them so you do take the risk of possibly causing more carbon build up on the secondary cats.
If you’re looking to remove all of them and not have to deal with possible clogging or anything, I’d say go for it. However, just keep in mind you’ll have to find an alternative to quiet down the exhaust if you’re not looking for a ricey type of sound whether it’s through a muffler or adding more resonators on it.
You’ll also have to live with the fact that your CEL will be on all the time since you’re removing the cats unless you get a bypass or tune to get rid of it.
