Originally Posted by Inv4drZm
Looks like an angle grinder w/ cutoff wheel could be used to cut that top section off of the bracket, then bend down the bracket a couple degrees until it tucks underneath the tray. You probably don't need that top bolt for the bracket. I did something like that when I put my switchpros in.
That may be what I send you doing. Need to test fit the Bussman and see if there's enough clearance with it still in that area.
Originally Posted by xxGxx
Their trays are beautiful and I'll be getting one soon myself so am subscribing here to see where you end up.
Any idea on what those units are?
They are beautiful. I attempted to make my own but it was looking a little haggard so I decided to just get it done right. Looking forward to getting this mounted up. I'll be sure to post back once it's done.
I do not know what those two units are.
Originally Posted by Trumpet
Why not bolt the modules to the power tray. Looks like there's enough meat to do so. Then ditch the toyota bracket.
I thought of doing that but I see two problems.
One is The cables are not very long so I'm limited to where I could mount them. Might not even be able to cleanly do it on the top. Second is I have a few other items being mounted on that bracket including two bussbars and a circuit breaker. I should probably check the cable lengths and see what my options are. Or even just keep them mounted below and out of sight. Might become a pain installing and removing but we'll see.
Whytey's 07 V8 Build Thread
2007 Toyota 4Runner Sport Edition V8, Elka 2.5 Suspension, Total Chaos UCA w/ Delta Uniball, Dobinsins C59-677V Rear Coils, Timbren Bumpstops, Prinsu Design Roof Rack, Baja Designs Squadron Sport Fogs, 285/70R17 BFG KO2, Blacked Out TE Rims, Spidertrax 1.25" Wheel Spacers, Satoshi Grill
