Old 02-26-2021, 04:57 PM #16
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
2008 V8 Sport Edition with Tow Package. I can fit a 32" BFG KO2 under there and the pan hard bar rubs it on rare occasion. I am hesitant to throw a 33" under there when I upgrade in a few weeks.
Pan Hard bar is going to be the main issue, not the two hitch.
EDIT: Tow hitch is a close second after getting under there over the weekend.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 07:22 PM #17
Goldy4R Goldy4R is offline
Goldy4R is on a distinguished road
Just to clarify, did you get the 33 to fit?
2008 V8 Limited 4wd - Galactic Gray - Fox 2.5 DSC - Dirty Deeds 20" exhaust - Shrockworks Sliders - Method MR701 - 285/70 KO2's -
Goldy4R is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 11:45 PM #18
PeteF PeteF is offline
PeteF is on a distinguished road
V8 Towing Package Spare Tire Size Question
FYI- the Curt brand tow hitch is a direct bolt-on replacement for the OEM hitch and maintains a 5000 pound towing capacity. It has more clearance... I am able to fit a new fully inflated 275/70/17 BFG KO2 in the spare location on my 04 Limited after replacing the hitch. $170 from etrailer.com
PeteF is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 11:59 PM #19
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Pretty sure the V8s have a 7,000lbs towing capacity. I’m not sure people are going to want to downgrade to 5,000lbs. Also, some are saying a 275/70/17 (32”) tire fits and a mildly worn and under inflated 285/70/17 (33”) tire may fit. It seems the jury is still out on the 285 though
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 11:41 AM #20
I can throw my 33" new BFG KO2 under there this weekend and see if it rubs. Will report back next week.
Old 06-10-2021, 11:33 AM #21
thmclaugh thmclaugh is offline
thmclaugh is on a distinguished road
@randy88fj62
I am currently encountering this issue myself - I have 285/70/17 E-rated Wildpeak AT3Ws and panhard bar is definitely being rubbed. Including a picture.
Should I just put it on my Sherpa roof rack for now and ratchet it down and over time as I do 5-tire rotations and it wears down, I may be able to deflate it a bit and fit it better? Have you come to any good solutions?
thmclaugh is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 12:07 PM #22
A friend told me I could potentially air down the spare and put a ratchet strap around it to keep it away from the pan hard bar.
Old 06-10-2021, 05:08 PM #23
Piggity Piggity is offline
Piggity will become famous soon enough
The ratchet strap is a good idea. It'll compress the tire a bit.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 01:51 PM #24
B.E. Coyote's Avatar
B.E. Coyote B.E. Coyote is offline
B.E. Coyote is on a distinguished road
bump- any updates?
I have the 4.7 and towing package. Would love 33's or as close to them as possible but keeping the spare in the factory location is a must
B.E. Coyote is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 02:25 PM #25
stopthefury stopthefury is offline
stopthefury is on a distinguished road
Originally Posted by jblinga View Post
I have an 03' with the factory hitch and I'm able to store my spare 285/70/17 in the factory location. Not sure if your hitch is different than mine, I'm able to leave the receiver in as well
Does anyone know the difference of the clearance of the factory tow hitch for the v8 03-05 v 06-09?
I am specifically asking for clearance reasons because I too want to size up and see if AT LEAST a 275/70/17 would fit in the factory spot?
06 SE v8 with towing here.
EDIT:
Good to know!!
Originally Posted by B.E. Coyote View Post
bump- any updates?
I want to know as welll!
stopthefury is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 03:26 PM #26
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Ahhhh yes....the question that's been asked for close to 15 yrs now.
And the answer remains the same...265/70/17 (BFG KO2).
There are a few things under there that impede...like the rear frame-mounted tow hitch, the panhard bar, and one or two spare tire braces. In fact, I think it was a couple yrs ago that I inquired about deleting those braces and the tow hitch for more room, but was told its a no-go.
For gaining that extra 1/2" of ground clearance, there's no way I'd consider anything other than keeping the spare underneath. If I wanted to go much bigger than 33", I'd look at a new rear carrier, but then that opens op a whole new realm of issues.
FYI the hitch on the '03 V8 is a smaller tow hitch.
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'03 4Runner 4X2 Lmtd V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 07:45 PM #27
4wheel parts says that is only 31.6" That would be disappointing. Might look at different hitches but don't want to give up capacity,
Old 11-04-2021, 11:27 AM #28
RBLACAUSA's Avatar
RBLACAUSA's Avatar
Ya it IS disappointing lol. With 2" CO lift in the front and probably 3" in the back w/Icon's dual-rate 3" springs, my 4Runner def looks under-gunned with the OEM wheels and BFG 265/70/17's, especially when I'm empty in the back. If I ever decide to get a rear tire carrier, or somehow one of you rocket scientist engineer forum guys can figure out a way to reasonably get a larger tire below, I'll upsize. But for now no way do I want to screw around with upsizing and having to carry the spare on roof or inside. My 265/70/17s have gotten me everywhere I've wanted to go in Death Valley, Panamint Valley, and Eastern Sierra mountains, and at this point of my life it seems like I'm doing less technical stuff and more traveled trails and fire roads.
'06 LX470
Spare tire size - v8 Billynath1988 4th Gen T4Rs 7 10-23-2015 06:51 PM
Calling all engineers and tech geeks - Tire size vs package weight and benefits crazydubman Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-25-2013 12:07 PM
Spare tire size, Will it fit? Derek G 4th Gen T4Rs 2 04-03-2013 12:34 PM
spare tire size ???? hairtumor Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-25-2010 05:06 PM
Spare Tire Size? CJ3Flyr General Discussions 4 06-15-2008 08:25 PM
