10-31-2018, 09:59 AM
#31
Real Name: John Iannacone
Originally Posted by SCMountaineer
Yes that’s the one!
10-31-2018, 11:58 AM
#32
New wheel
Here’s the wheel I swapped in. For now the other controls are duplicates of the original ones. I may later try to use them for other functions
10-31-2018, 07:32 PM
#33
Real Name: Blake
Real Name: Blake
Soo
@ Johns06yota
I've been interested in this, since you first posted about it, and even now buying your "old" one off of you.... my concern is, if you wanted to upgrade to get the RH controls, I'm thinking "wouldn't I want them too?". However I'm trying to figure out what that D-pad and other controls on the RH side would operate... What are you planning on using them for? It looks like you have an AM HU, and I do as well (Pioneer AVH-2300NEX).
Also, the interior blackout job you did looks great! I'll probably tackle that this summer along with the LED upgrade, until then I'll just drool over pics of yours. I have a Natural White on Tan leather... I don't mind the Tan, actually I'm fond of it, but the blackout really helps keeping the rig look more modern.
EDIT: Also, the "New" one seems like it's not as thick compared to the "old" one... I'm assuming that's bc of the OEM leather vs the AM Leather wrap, is this the case? Would you also mind posting the Diameter of both wheels? As others have stated, it seems the 5th gens are smaller than the 4th gens, and I just want to see by how much. Seems like a small issue, but then again the steering wheel is something you use the most in a car, so the little things matter.
22 SR5 Prem 4X4- Magnetic Gray
07 V8 Limited 4X4 - Natural White (SOLD)--> "Moby Dick" Build Thread
10-31-2018, 08:00 PM
#34
Originally Posted by Flash Runner
Soo
@ Johns06yota
So my hope with the other controls was to see if any of the factory pinouts would control play pause functions and things like that in the radio since I do have an aftermarket kenwood unit. The issue I ran into is that none of the other empty pins on the clock spring did anything currently and I really didn't want to rip my dash back out to check the dip switches on I believe its a pac unit for steering wheel controls. They may work but I have no way of knowing at the moment. So my hope is that if I am unable to get that to work that I will eventually swap instrument clusters from a 2016 and forward tacoma to update the look and also gain those other controls (right now im just using them as extra volume controls) And yes the new one is a little thinner since its the oem leather but its not too big of a difference. The new one is similar to our 4th gen thickness wise. I honestly kind of liked the thicker feel of the other one, it had a better grip than the new one I just put in. I would send you the dimensions but I'm at college right now so I dont have my tape measure with me. In regard to size difference, I had put my 4th gen wheel and that wheel together when i was home and the 5th gen one was slightly smaller but not by much. After the amount of time I've had it, it didn't have any noticeable difference. I think the reason it seems smaller is due to the design of the handles. These are much larger than the 4th gen ones but they havent caused any issues for me
Also thanks! I appreciate all the feedback because it does help motivate me to do more haha
11-07-2018, 11:17 AM
#35
I sent you a PM.
I'm interested in the Tacoma steering with the left hand controls straight plug and play into the 4th gen.
11-07-2018, 11:57 AM
#36
Wheel no longer available
Originally Posted by Run4ever*
I sent you a PM.
Hey really sorry the wheel was sold. I should have updated the post
03-08-2019, 05:06 PM
#37
Soo
@ Johns06yota
I have an android head unit , link below.
I can program any of the buttons on the steering wheel to do what every I want. It works of resistance when teh button is pressed and the head unit detects that resistance level which is unique to each button.
I think if you make sure all buttons are connected, it should allow you to program the all the buttons to do whatever you want.
Android 8.0 Universal 2 DIN 32GB ROM OCTACORE
– E1 Living
03-08-2019, 06:45 PM
#38
this probably cheaper then my ebay piano black steering wheel and buying the cell buttons.
04 4runner Sport Edition V8
-MODS- Maxtrac Lift Spindles | Bilstein 5100/5160| Tacoma frt springs | MT LT 3in reat springs | eBay UCA | SS brakelines | 4crawler body lift | 17 level8 punch | At3 315/70/17 | K&N cai | black clazzios |
Build thread
03-09-2019, 12:42 AM
#39
Real Name: Ed
Real Name: Ed
Steering wheel looks awesome!
I'd like to know how you got your HVAC reverse polarized display to look so bright???
03-09-2019, 10:25 AM
#40
How do you like that piano black wheel, quality-wise? I’ve been considering getting one of those for awhile now, or the other version they offer that looks like black/gray wood grain. Since my SR5 doesn’t have any steering wheel controls at all, I unfortunately can’t use these newer style wheels, mainly because I’d hate having non functional buttons.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
03-09-2019, 04:11 PM
#41
I really like it and got the sport version with the indentions and bumps. that help alot off road. but the smooth parts take a little getting used to. the wheel is awesome quality and where the old trim attached i had to file it down a little bit under the steering wheel
Build thread
03-09-2019, 11:30 PM
#42
Thanks! and I make kits now that I sell on my site iannaconeautoaccessories.com
But the bulbs I use are from superbrightleds.com and they are the t4 wedge style. I also retained the factory ground pin but ran a 12 volt positive line from my cig outlet for power
03-10-2019, 12:41 PM
#43
Real Name: Ed
Real Name: Ed
You now have a customer. Thanks!!
03-10-2019, 01:27 PM
#44
Real Name: Skip
Real Name: Skip
Does this work for a 2004 Limited Dual Zone display?
2004 Limited V8
03-10-2019, 01:49 PM
#45
Real Name: Chris
Real Name: Chris
Originally Posted by simple
This is seriously awesome. My only hesitation here is the airbag recall.
Airbag recall is passenger side only. There is no recall for the DS airbag that I am aware of.
