05-14-2018, 10:17 AM
Front Strut stuck
Good morning
This Saturday I started my axle and suspension swap. I removed the axle without any issue, and was able to remove the top 3 bolts from the strut and also remove the bolt that connects the strut to the LCA. I also removed the sway bar for extra clearance. I haven't messed with the cam bolts on the LCA yet since I think I have enough room to remove the existing strut, but the thing is stuck on the strut bucket/housing. All the videos I see, after removing the top 3 nuts, and the LCA bolt it just slides out easy, but mine seems frozen. Am I missing something, or should I just try to pry it out? Im also considering going thru the engine compartment and bang on the one bolt to try to free it, but just would like to verify this with 4runner gurus before I get medieval. I'm installing some ICONs i purchased back during black friday. The truck is a 03 4runner limited with XREAS.
Thanks for the help!
-Jose
05-14-2018, 10:50 AM
[Yeah I had the same issue. I ended up doing a combo of hammering in a flathead screwdriver between the strut and the tower bracket, and hammering a pipe that was resting on the top-through the engin bay. All while heating up the area with a torch. Gotta break that rust weld. Sucker was really on there!
2005 4Runner Sport 4wd v6 -totaled!
2003 Lexus GX470
05-14-2018, 11:14 AM
You're not angry enough yet. Break out the hammer and hearing protection and have at it.
05-14-2018, 11:31 AM
don't forget the hearing pro.... start banging on metal stuff under there without it and your ears will be ringing for a while. Ask me how I know...
05-14-2018, 11:43 AM
Real Name: Derek
Real Name: Derek
Originally Posted by ndjose
Good morning
-Jose
Did you pull the 2 bolts (48068M/48069H) out of the control arm bracket (48625/48626)? That helps, support the UCA and caliper with a bungee cord or something...so you don't kill the ABS wire.
I guess if you have the axle out you already did this.
You can force the LCA down with a breaker bar or some bar like device.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
05-14-2018, 12:17 PM
I did remove those two lower bolts, so I guess its time to get "angry".
05-14-2018, 03:36 PM
Real Name: Elliott
Real Name: Elliott
Mark the alignment cams with a grease pencil so you can set them back to somewhat drivable, and loosen them. No reason to have to force the LCA down, it should easily hang on its own.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
05-14-2018, 07:04 PM
Step (with your big old foot) on the LCA near the shock and force it down. Should drop a good 3-5".
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
05-14-2018, 07:41 PM
Front Strut stuck
Air hammer on the bucket that holds the top hat of the dampers
And/or persuasion bar on your pry bar
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
05-15-2018, 12:06 PM
Good morning
-Jose
I had the same issue an d banged the crap out of it for an hour. Finally decided to try and bang a 1" wide chisel between the top of the strut and the bottom of the mount and it came out in less than a minute. When I got to the other side, I skipped all the banging and went right to the chisel and it again was less than a minute to get out.
05-15-2018, 01:55 PM
I had a bad day at work this morning, so at lunch time I got it out ;)
Screw driver + hammer + frustration = success
thanks again for all the help!
-Jose
