05-18-2018, 12:59 PM
285 rubbing question
Hey all!
Picked up some used Duratrac 285s from Craigslist and just got them mounted up. Since they're used they seem to clear everything except my UCA arms and maybe my swaybar?
I do not have spacers installed but have a brand new set of Spidertraxx in the box still and if I'd prefer to run without them if I can. Can this stuff be resolved with a caster adjustment that I read about somewhere on here?
Let me know what you all think!
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
05-18-2018, 01:13 PM
Probably going to need those spacers, or new rims...
05-18-2018, 01:36 PM
Real Name: Steve
Real Name: Steve
Caster is the front to back placement in the wheel well. You're gonna need those spacers. Be diligent about install and you'll have no issues.
Clean the hubs well, place the spacer on. Torque to the recommended values -- do NOT over torque! It is not any better than under torquing. Check them every rotation, or sooner if it worries you.
I've had spacers for going on 20k miles and haven't had a single lug loosen, as confirmed with my torque wrench.
'15 Mag Gray LE -- TOTALED | '14 TE wheels - dipped black, Falken AT3W 285/70/17 | SPC Adjustable UCAs | Daystar 2.5/1.5 top spacer lift | RCI Fuel Tank Skid (Steel) | Shrockworks Step Sliders (trimmed LE Rocker Trim) | SR5 front end conversion
'08 BP Urban Runner -- 5100 fronts at .85 with Toytec 620# springs | SPC Adjustable UCAs | Plastics Guy Front Bump Stops | ICON VS 2.0 Rear with Toytec Superflex 2 inch springs | RCI Transition, Front and Transmission Steel Skid | LT275/65/18 Falken Wildpeak A/T3W | 1.25 inch wheels spacers
www.4runnerfamily.com | IG: Runn4est
05-18-2018, 01:41 PM
Ahhh dang! Ok! I thought I got away with murder not having to trim anything and maybe only needing a simple alignment. I knew it wouldn't be that easy. I've watched a few install videos on the spacer installs and feel comfortable with it. I have a cordless impact, torque wrench, and OCD levels of patience.
I mean putting them on is basically just red loctite (included), starting the bolts (curved side inward) by hand, tighten a bit in star pattern to get it centered, and then torque to recommended values in star patter...twice.
Do I have that right? After that I'm sure I'll need an alignment, eh? I went from 265/65's with no spacers. Unless you guys think I won't!
Also, I have to install all four spacers even if the back doesn't rub, right?
05-18-2018, 02:26 PM
Real Name: Steve
Real Name: Steve
Your install steps sound good, just also make sure the hub surface is clean of debris and rust and as smooth as you can get it. And personally, I would get an alignment.
You don't need to run the spacers in the back. I think a lot of people only run one set.
05-18-2018, 02:52 PM
Real Name: Chris
Real Name: Chris
You might have to install longer studs on the front for use with the spacers, I did. I the near future they are coming off for a set of 5th gen wheels that will fit with out the scary spacers.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
05-18-2018, 03:15 PM
Ideally I’ll be getting wheels in the future. Do the 5th gens have enough backspacing for 285s?!
Also, anyone care to double check my work?
Is that hub surface clean enough or should I keep scrubbing with the steel wool and brake cleaner?
Also, stud length look ok?
05-18-2018, 05:59 PM
05-18-2018, 11:34 PM
Looking good! The best way to check is to flex it out in a parking lot of on a mellow trail. That way you’ll know if you need the cab mount chop or anything else.
Keep an eye out for some FJ cruiser or 5th gen trail edition wheels. They stick out 15mm more than your wheels and they are 1/2” wider so they work well with 285s and don’t need spacers.
'08 SR5 with Old Man Emu 884 front springs, Toytec Superflex rear springs, 285/70r17 KO2, full skids and sliders from RCI.
05-19-2018, 03:30 PM
Thanks man! Going to head out to a mellow trail tomorrow to test it out.
I see the TE wheels come up pretty regularly here on CL for like $4-500 with tires still on them sometimes. I'll put it on the list below replacing these eBay uniball UCAs and getting my DT headers installed.
05-19-2018, 04:29 PM
CL is where I found mine for $500, a little pricey but they were taken off a brand new TRD OR before the guy took delivery. Overall I’m happy with the wheels, especially with how the valve stem is protected by the rim. 285s are going on after my 255/80 st maxx wear out this fall.
05-21-2018, 01:11 PM
So I'm taking it in for an alignment today at a place that I've been going to for a few years that specializes in off-road and race applications. Should I request anything special? I don't know yet whether or not I have body mount rubbing (that's what she...) because I haven't wheeled it yet, but judging by the picture above should I maybe have my caster set forward a degree or two to be on the safe side?
Thanks!
Also, it drives pretty well right now but I can tell a proper alignment will help. I haven't felt any vibration issues at highway speeds or anything. I need about another 50 miles before I check the torque on the spacers, but yeah...kind of pumped.
05-21-2018, 01:33 PM
Real Name: Chris
Real Name: Chris
Thanks!
They might not touch it with spacers on, FYI. My local shop wouldn't, had to remove them for alignment. And thats what my studs looked like too, I bought some Matrix rear studs off RockAuto and got some ET lugs from All Pro Off Road and some red loctite.
https://www.allprooffroad.com/shop/e...read-lug-nuts/
05-21-2018, 01:36 PM
you should be fine on the street. if you leave the pavement thats going to rub.
05-21-2018, 01:45 PM
This is primarily a trail rig, so that will be a problem. Should I have them bump the caster forward then? If so, how much is recommended?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
