Well, I just installed the new cluster lens and it looks great!
Here is a step-by-step clarification:
1) Remove the lower panel below the steering wheel
To do this:
a) Remove the 2 nuts on the lower part of the panel
b) Remove the plastic ring around the keyhole (not the lighted plastic part, the part that surrounds it.
c) Pull the lower panel from the car starting at the bottom. It should just pop right off
d) Disconnect the electrical cables if you need more room. (Center Lock cable, AC 115v, TRAC off, temperature sensor)
2) Remove the top half of the cluster. (Containing the cluster light switch, directional arrows, plastic bezel that separates the speed, fuel gauges, and tach)
a) Just pull from one of the ends and it should pop right off. Be careful not to break any tabs
b) Disconnect the blue and white electrical connectors from the top half of the cluster
3) Remove the cluster lens
a) Unscrew the 2 philips screws that hold the lens down
b) Gently push the bottom 2 plastic tabs and the top 2 plastic tabs
c) The cluster should pop right off
4) Replace the cluster lens with the new one
using clean, new, rubber gloves to prevent finger prints and dirt
5) Put the car back together and enjoy!
