Old 05-03-2021, 11:05 AM #16
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
Wink
Originally Posted by lonkelm View Post
Whew, that was some work.
Tried sway bar bushings first. Improved the cornering a bit, but didn’t fix my issue.
Went ahead and replaced both LCAs which included the ball joint. Since it was apart, I also did the inner and outer tie rods on both sides. After alignment she drives great and clunk is gone!
No kidding, if you aren’t cussing while getting the LCA off, you are doing it wrong. The passenger side totally ceased up. Took 5 sawzall blades to cut her off! Not for the faint of heart.
Took her back to NTB for an alignment and was informed my “lifetime alignment” expires next month. I’m still on the same tires I bought it with. Lifetime?
When I was at an alignment shop years ago a mechanic said I needed to replace the lower control arms (with bushings). I bought him hew ones from Amazon and he installed them.
I also had him replace the sway bars, but ball joints in mine are OEM.
No front-end noises in my 2005 with 150,000 miles.
FordF150 is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 03:23 PM #17
Vengeance Vengeance is offline
Vengeance is on a distinguished road
Originally Posted by nlau87 View Post
I get a front end noise going over dips or bumps. I’ve removed the skip plates and the sway bar including the links but no luck.. the sound didn’t go away and it drives me crazy. I have bilstein 5100 installed about 4 years ago and also had my LCA’s replaced about 2 years ago. Any ideas what might be the issue?
Video with sound:
Toyota 4Runner (2007 4th gen) front end noise over dips or bumps - YouTube
Hey man, did you ever figure out what your clunk problem was? I watched your YouTube video and it sounds similar to my clunk, and I also have the bilsteins 5100.
Vengeance is offline   Reply With QuoteReply With Quote
Old 08-22-2023, 10:25 PM #18
VertigoPerformance VertigoPerformance is offline
VertigoPerformance is on a distinguished road
Time to revive an old thread.
I have a clunk, only turning left out of a parking spot on eneven ground, usually when the truck has been sitting a few hours.
Years ago I had a clunk and it was the sway bar bushings which I replaced.
The upper control arms were replaced five years ago with Camburgs to accommodate the 4” lift.
The lowers had the bushings replaced five years ago.
Recently I greased the entire front end of the truck, any part that moved got greased even the swaybar bushings to free them up and the clunk is still there.
I thought if it was the sway bar bushings again I would grease them first if the clunk disappeared I would replace them.
Also, with a lift kit the steering stops will clunk if the wheels are turned locked one way or the other so I keep grease on those to stop that from happening
Because my 5100s l started leaking I replaced them with Bilstein 6112 and new 650lb springs.
Any suggestions?
2003 V8 Sport Toytec/Bilstein lift, 3" front, 2" rear / 1/2" leveling kit / Front diff drop kit / Camburg upper A arms / Mayem Rampage 17x9.-12 Matte black wheels / Duratrac 265/70R17 Tires
VertigoPerformance is offline   Reply With QuoteReply With Quote
Old 08-24-2023, 09:14 AM #19
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
I don't have any clunking noise, but have you guys replace both inner and out tie rods?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-15-2023, 10:29 PM #20
peak2peak peak2peak is offline
peak2peak is on a distinguished road
I had a very similar issue. After looking under my rig, a bolt holding on the skid plate was loose. My stabilizer bar bushing was also going bad which also added to the noise. May be worth a check.
peak2peak is offline   Reply With QuoteReply With Quote
Old 09-21-2023, 01:30 PM #21
2003V8LTD 2003V8LTD is offline
2003V8LTD will become famous soon enough
FWIW, I had a front end clunk. Replaced sway bar bushings with urethane ones that I found in a very low durometer. Problem completely went away and the overall dynamics of the car are very good now.
I’ve been trying to chase down this ‘clunk’ that happens when going over a concrete drain curb, or turning while backing.
When I back up and do almost full turn of the wheel ( when backing from my driveway out of the garage to run and then exit my drive) I hear this significant ‘clunk’ and can feel it in the steering wheel.
When turned and going over the drain curb to my drive, I hear and feel the same noise. Backing from most parking spots I get the same.
It’s not a ‘click click click’ that you would expect with a CV joint.
This weekend I put a wrench on every nut I can find. I put 5100’s in 3 years ago so I know the suspension well.
I had a bad wheel bearing on the passanger side that I was hoping was responsible. That’s now replaced.
I lifted the wheels and all tires are solid, so wheel bearings are good. I feel no wiggle in any joints as I try to move the tires while up on the jack. All feel tight.
I’m wondering what this group suggests to check. I can’t find anything loose, but it’s some clear suspension clunk when turning tight and/or going over a dip at low speed. I don’t hear it over normal bumps and pot holes while driving.
Any ideas would be appreciated
2003V8LTD is offline   Reply With QuoteReply With Quote
front end clunk Mass 4runner 5th gen T4Rs 9 03-15-2021 11:05 PM
front end clunk adam2562 5th gen T4Rs 30 06-25-2020 07:59 PM
Front end clunk help diverscale 3rd gen T4Rs 17 09-04-2019 01:39 PM
front end clunk brad4043 3rd gen T4Rs 4 07-08-2011 01:46 PM
Front end clunk on 07 SR5 2WD McInnis 03 4th Gen T4Rs 8 02-14-2010 02:41 PM
